Daytime Running Light Circuit Needed
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=139124
Printed Date: May 02, 2024 at 4:27 AM
Topic: Daytime Running Light Circuit Needed
Posted By: gordyg
Subject: Daytime Running Light Circuit Needed
Date Posted: June 25, 2015 at 7:46 PM
I am installing aftermarket Daytime Running Lights that will turn on when the ignition switch is on. However, I would like these to turn off automatically when my parking/headlights are turned on. How can I achieve this?
Posted By: dablakmark8
Date Posted: November 12, 2015 at 4:55 PM
use a relay to cut day time running lights positive or negative.Buy utilizing the pin 85 and 86 to energize the coil.
------------- the only interesting answers are the one that destroys the question.
Posted By: gordyg
Date Posted: November 15, 2015 at 7:52 PM
I didnt quite word my question properly.
So what I am trying to achieve is that the front parking/signal lamp has a two filament bulb one for parking (lower intensity) and one for signal (higher intensity). So during the day when the ignition is on I can use a relay to turn on the turn signal filament as it is brighter which is fine. However, I would like to be be able to turn this filament (or relay running it)off by either of the following conditions:
A)When I use the turn signal during the day.
B)When parking lights are turned.
How can this be achieved?
