So I bought a LED light bar and have it wired up and working, but I am just not sure I have gone the right way about it, so I was hoping some people could share their opinion.
Here is the diagram they supplied me with.
Their switch has lights, hence the + and - going to it and the white wire (86) has the + signal coming from the switch, to the relay.
So I cut the switch away as I have my own switch. I initially wanted the white wire to be the switching wire between the high beam and relay, but my high beam earth switches, so that wasn't an option. I instead ran a constant + to the other side of the switch for the white wire and I connected the B (85) wire to the high beams earth switching wire. As you can see, the B wire is where the - for the light bar splices in.
So this is what I have been building to... The earth wire for the high beam might not be built to handle close to 500W, so I am wondering if maybe I should cut the earth wire that goes to the light bar and earth it to the body separately. Does that sound right?
Hope that makes sense! I read it twice and naturally I can make sense of it, but I am the one who wrote it. If anyone needs some clarification, feel free to tell me so.
If you are only energizing a relay you would be fine. But you ground is shared and needs to be separated.
By moving the light side to chassis ground. So the Vehicle High bean ground is not carrying both grounds, only a additional relay ground.
If you want to use the high beam ground. you risk overloading it the way you have it.
No problem.
