How do you connect a lighted DPST Switch?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=141959
Printed Date: April 28, 2024 at 10:02 AM
Topic: How do you connect a lighted DPST Switch?
Posted By: aviator172
Subject: How do you connect a lighted DPST Switch?
Date Posted: November 03, 2016 at 10:59 AM
I have a 4 pole, DPST LED illuminated rocker switch that says the Blue LED will come on when the switch is in use, powering a device.
No matter what I try, I cannot get the Blue LED to come on?
Anyone know how to properly connect these switches to make the LED come on using 12v DC ?
Posted By: i am an idiot
Date Posted: November 03, 2016 at 8:46 PM
1 of the terminals should be labeled ground. Did you ground that terminal?
Date Posted: November 04, 2016 at 8:46 AM
None of the terminals are marked at all. No instructions came with it
Date Posted: November 04, 2016 at 8:51 AM
I finally figured it out on my own. Looking at the pins directly, the
top left pin connected to 12v+ (power)
top right pin connected to ground
bottom left pin connected to load's HOT (12v+) side
Now the switch turns on the load and the blue LED lights up
Hope this helps someone else. Drop a note if so. I'm following this thread via email.
