Prius plugin 2012 hazard lights flashing
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=142077
Printed Date: May 03, 2024 at 2:22 AM
Topic: Prius plugin 2012 hazard lights flashing
Posted By: jakeo1274
Subject: Prius plugin 2012 hazard lights flashing
Date Posted: November 21, 2016 at 5:48 PM
My issue with 2012 Prius plugin , the hazard lights flash whenever the car is in motion . So, when the hazard lights button is not engaged the hazard lights will rapidly flash as the speed of the car increases.
I've changed the flasher relay module , I've changed all the exterior light bulbs that flash, I've changed the signal switch on the steering column and I've changed the hazard lights button , all of which have not resolved the problem .
At this time I need to start to trace the wires and trouble shoot
So i need to get a copy of a 2012 Toyota Prius Electrical Wiring Diagram Manual
Would anyone have a copy of this diagram and any other trouble shooting suggestions
J
------------- Jjo
