2008 Chevrolet Silverado, LED Strips as Puddle Lights
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=146438
Printed Date: May 21, 2024 at 5:03 AM
Topic: 2008 Chevrolet Silverado, LED Strips as Puddle Lights
Posted By: Ynot80
Subject: 2008 Chevrolet Silverado, LED Strips as Puddle Lights
Date Posted: September 10, 2020 at 7:53 PM
I have a 2008 Silverado and I am going to put a set of LED strip lights under the rocker panels to use as puddle lights when you open the doors . I was looking at the wiring and the truck has a negative door trigger and the lights need positive so I know I need to do a relay. I noticed that the truck has a positive dome light supervision wire . Could I use that instead of the door trigger to power the lights on when the door opens ? Just thinking if that would work it'd save me having to wire up a relay .
Posted By: mgoetz74
Date Posted: September 11, 2020 at 1:01 PM
i hooked mine to the door trigger. I hooked negative for the lights to the door trigger and the positive to a constant so ever time it see's the negative the light come on. Had it hooked up that way for 3 yrs now and no problems
------------- 33 years as a installer now just a retired old guy. Favorite thing to install/topic are remote starts/car alarms. Stop using test lights!!!
Posted By: Ynot80
Date Posted: September 11, 2020 at 5:21 PM
Ill give that a try. The strips I bought are multi function ( turn signal, parking and puddle light) I dont want anything but the puddle lights so Im assuming hooking it up like you described shouldnt cause any issues. If it doesnt work for some reason Ill just wire a relay up.
