rear stop light flasher
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=26780
Printed Date: May 05, 2026 at 9:59 PM
Topic: rear stop light flasher
Posted By: j.a.kelly
Subject: rear stop light flasher
Date Posted: February 19, 2004 at 8:16 AM
Hi there, im in the UK and want to add summat to my car so the brake lights flash on and off from a switch.
can anybody post up a diagram to acheive this??
there is one hitch tho...i have a third high level brake light, and would need to isolate this from the flashing circuit, or if it is possible....to make this flash in an opposite sequece to the normal brake lights?!
Hope someone can help, thanx
Thanx 4 your time
Posted By: Teamrf
Date Posted: February 19, 2004 at 7:16 PM
Well it depends if you want to control it or not...You can just use a relay and a toggle switch. Most of the time all three lights use the same wire. Meaning one wire will come from all three wires, and tie together somewhere in the car. I'm not quite sure how you can get the two lights to flash without the three light.
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
Posted By: Dauber
Date Posted: February 21, 2004 at 2:02 PM
Do you want the option of when your pressing the brake and by the flick of the switch the lights will flash alternately but only flash when pressing the brake, or as soon as you flick the switch its constantly flashing all the time?
Kyle@Audio Obsession Sound
Date Posted: February 23, 2004 at 3:57 AM
hi there
yeah i want it so i can activate the system by switch, to run itself, not when i touch the brake light. This kind of device is used in the UK by the emergency services, but looks very effective, i often have to stop in dangerous places on dark roads when im at work so need a setup like this so my car can be seen and not crashed into!!!
hope this helps....a wiring diagram and what i will need would help greatly, thanx
Thanx 4 your time
Posted By: Dauber
Date Posted: February 23, 2004 at 2:56 PM
Wouldn't your hazark lights work in this case, just curious.  I have figured a way to make your brake lights alternate based on a switch, its just I'm trying to figure a way to isolate so it doesn't screw up your factory wiring.
Date Posted: February 24, 2004 at 1:48 PM
oh that sounds promising!!!
yeah but hazards alone have proved not to be as eye catching (i found that out after 2 new bumpers!)
ive sent you a PM regards the diagram mate, thanks so much.
Thanx 4 your time
Date Posted: February 26, 2004 at 6:42 AM
did you get my email mate?!
i think that i may have worked out the pins on your diagram...correct me if im wrong from the layout below (im using the way up you drew them?!)
                                                      87
                                   86              87a            85
                                                      30
Thanx 4 your time
