wiring extra lights
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=45528
Printed Date: May 06, 2026 at 1:50 PM
Topic: wiring extra lights
Posted By: martikimgo
Subject: wiring extra lights
Date Posted: December 19, 2004 at 4:21 PM
 Hi this is my first post, I found this site, forum by looking for an easy answer to a problem I have . I own a 1994 Toyota Hilux and I want to wire in extra driving lights. There is a wired in harness for fog lights , I am going to use this harness ,but I also want to put in another harness/ loom, wiring etc for another two extra lights of a higher wattage is there any sites files that are easy to find on the web that I could look at. I have looked @  various but some seem to be a little bit confusing. Thanx
martikimgo
Posted By: Hymer
Date Posted: December 19, 2004 at 5:30 PM
You should have 2 wires in that existing harness +12 (when the switch is depressed) and a ground, Just splice your extra wires right off this harness your factory switch will control all those lites, and it should be relayed so you won't have any overload problems. You may have to add a fuse for the factory harness to get it powered up...
Good luck!
