turn signal. what to try next?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=52349
Printed Date: May 05, 2026 at 9:35 PM
Topic: turn signal. what to try next?
Posted By: ryano
Subject: turn signal. what to try next?
Date Posted: March 22, 2005 at 7:07 AM
The left turn signal on my rodeo is out.  It started by the indicator on the dash blinking fast and the relay clicking fast, then the indicator light went out, but the relay is still clicking fast.  So far I have tried to replace all turn signal bulbs on both sides, and the flasher relay.  I took a test light and Im getting a signal under the dash where the jack is coming from the steering column.  The fuse is also good.  I looked at the wiring by back and front bulb, but dont see a loose wire, or anything touching ground.  I followed it back until it went into a big bundle with all other wires.  Any info would be appreciated.  Also a wiring diagram would help a lot.  Thanks in advance.
Posted By: ss-installer
Date Posted: March 22, 2005 at 8:23 AM
try replacing the bulb in the dash. more times than not if you still hear a clicking then its a bulb. if the front and rear bulbs look good go ahead and replace them anyway, you never know. use bulb grease too.
Posted By: ryano
Date Posted: March 24, 2005 at 6:57 AM
Every bulb in the vehicle that has to do with the turn signals is now replaced, but I am still having the same problem.  Do I need to start checking the wiring?  I can hear in clicking.  Would this mean the problem is after the flasher relay?  Any other tips on what to check, or the easiest way of checking the wiring?
Posted By: soundmasta
Date Posted: March 24, 2005 at 7:12 AM
i have another turnsignal ?. in a 91 jeep cheeroke both turn signals and the hazard lights are out. there is no clicking sounds, just nothing. the parking lights come on when they are supposed to, but no turn indicator lights. any ideas?
Posted By: overworked2
Date Posted: March 25, 2005 at 2:34 AM
soundmasta have you tryed replacing the actual flasher unit?
ryano, have you had any work done to the car recently? like maybe an alarm installed? my thoughts are that maybe when this was being installed a line coming from the flasher unit may have been cut slightly and has since come apart entirely, meaning that the flasher will still be active but somewhere down the line the power isn't getting through, suggesting that yes there is a cut cable, to try and eliminate this as a problem, using a test light or multimeter if there is a signal cmoing out then you have a cut wire somewhere, two options try to locate the cut, or run new wire to the flasher bulbs (maybe much easier then you think) if there is no signal coming out but it is still clicking then you have a faulty flasher unit that needs to be replaced.
Let us know how you go.
Check all advice given with a meter
