LED on when switch is off
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=53424
Printed Date: May 06, 2026 at 1:23 AM
Topic: LED on when switch is off
Posted By: mr dibb
Subject: LED on when switch is off
Date Posted: April 06, 2005 at 7:59 PM
Hi, I have a remote start I just installed. I disable it every night when i park it in the garage. Is there a way to have an LED light up when the Switch is in the off position? The LED should only light when the car is on acc. Thanks!
Posted By: dablakmark8
Date Posted: May 06, 2005 at 11:23 AM
use a relay to change polarity
