wiring 4 leds in a computer
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=61731
Printed Date: June 08, 2024 at 7:45 AM
Topic: wiring 4 leds in a computer
Posted By: danieljaluise
Subject: wiring 4 leds in a computer
Date Posted: August 20, 2005 at 8:56 AM
Here are the specs for the LED's:
Power Dissipation: 120 mW
Peak Foward Current: 100 mA
Continuous Foward Current: 30 mA
Reverse Voltage: 5 V
Operating Temperature Range: -20°C to 80°C
Storage Temperature Range: -30°C to 100°C
Lead Soldering Temperature: 260°C for 3 sec.
Luminous Intensity: 2500 mcd
Viewing Angle: 15°
Forward Voltage: 3.50 V
Reverse Current: 100 ìA
This is in a computer, so I will have access to both a 12volt source and a 5volt source. All I want to know is:
1. How to wire them? Series or Parallel?
2. Should I use the 12 volt or 5 volt wire?
3. Do I need a resistor(s)?
Posted By: santiago
Date Posted: August 22, 2005 at 12:36 AM
You can wire them in either series or parallel, and you can also use either 12 or 5 volts.
If you wire the 4 LED's in Parallel:
and use the:
-5 Volt supply, then you should use a 15 ohm resistor (exact value required is 12.5 ohm but 15 is more common) rated at 1/4th watt (exact value needed is 0.18 watts)
-12 Volt supply, use a 75ohm (exact = 70.8333 watts) resistor rated at 2 watts (exact = 1.02 watts)
If you wire the 4 LED's in Series:
and use the:
-5 Volt supply, then you will not need a resistor - in fact, you won't quite have enough juice to fully power all 4 LEDs (they'll just be slightly dimmer than 2500mcd)
-12 Volt supply, then you will not need a resistor. same results as with the 5 volt wire, but brighter.
If you wire them in parallel i would recommend the 5 volt supply, wiring the resistor in series with the group of (paralleled) LEDs. If you wire them in series, i would recommend the 12 volt supply.
But personally i'd say save yourself the hassle/money of finding/buying a resistor and wire the 4 LEDs in series to the 12 Volt supply. That will work out nicely.
------------- -Santiago-
MECP certified (Bronze)
