2004 Honda Civic EX LED Tubes
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=63176
Printed Date: May 22, 2024 at 9:37 PM
Topic: 2004 Honda Civic EX LED Tubes
Posted By: randeye
Subject: 2004 Honda Civic EX LED Tubes
Date Posted: September 23, 2005 at 8:47 PM
Ok, I have been beating my brains out trying to find information on wiring diagrams, harness pinouts and such, and found LOTS of info, NONE of which was what I need.
See, all I want to do is hook up some interior LED tubes for footwell lighting, and I want it to behave like my dome lights: Off, Door, and On.
I pulled the front interior lighting housing out and found my wire, the RED / green lead, the one that obviously must come from the tarry circuit connected to the door switches.
Lo and behold, the wiring from the interior lighting housing connects to a wiring harness just above the housing's mounting position. Its path seemed obvious enough, so when I traced the wiring to the driver's side kick panel, there I found my current stopping point: A huge gaggle of wires, harnesses, wrapping, tubing, etc.
SOOOOOOO, how in the #$&% do I find my needle in a haystack. I have been online for hours and have found out how to replace my radio, how to install an ashtray, and that there is an alarm plug on the driver's side that has all the wires from the door switches, and if I hook up my circuit tester just right I can toot my horn in a rapid machine-gun like fashion as the probe tip skips around the lead. All of this is very fun and entertaining, but CAN ANYONE TELL ME WHERE THE TARRY CIRCUIT AND/OR WIRING IS LOCATED? PLEASE? :)
It's such a simple thing: hook up two LED tubes to a wire. I just don't feel like tearing up all of my harnesses and spending hours searching for a needle in a haystack, and before anyone asks, yes, I have read the FAQ and used the search engine. I have searched literally for over six hours on every web site from crutchfield to jcwhitney to 7thgencivic.com to here, trust me, I really have done my homework on this one, but I keep coming up zilch. I even went to Autozone to look at their manuals, and none of them would help me either.
Any ideas? Anyone? Bueller?
Posted By: randeye
Date Posted: September 24, 2005 at 7:55 AM
SOMEBODYout there has to know the answer, or have a manual or something that does!!! I just don't want to hav to pay 120 dollars for some manuals for ONE stinkin' wire!!!
C'mon peeps! Help a brutha out!
Posted By: Autoobsession
Date Posted: September 24, 2005 at 2:35 PM
Just go to the main domelight. There will be three wires on it. One will be constant 12volts, one will be ground, and one will be your switched. This car has a negative domelight circuit which means when the doors are closed the switched wire will show you 12volts. When the doors are opened it will switch to negative. So assuming there are two wires on your neon tubes, one for power and one for ground this is what you have to do. Hook up the 12volt wire to 12volts which u can find coming from the ignition switch. It will be a white wire. Then you can hook up the ground wire to the negative switched wire from the dome light. -------------
Posted By: Stripes26051
Date Posted: September 29, 2005 at 11:03 PM
why not just run your own wire from the dome light to where you need it instead of putting up with all that bs
------------- 89 honda crx 1 15" Power HX2 jblbp1200.1 rockford coaxials 4 channel comin soon
Posted By: 93cougarxr7se
Date Posted: October 15, 2005 at 1:31 AM
Ground to a common ground, any metal. Then take the positive from any interior light that comes on when the door opens. Ash tray light, or something. Floor light. Shouldn't be too hard. Get a digital multimeter (not bad to have anyway) and put the ground on the chassis, and start probing around for a positive. When you get 12V, you have your positive. Shut the door/interior lights off, and if it goes to 0V, you're good. Or if there's some bulb, just splice into the wiring for it. Neons shouldn't pull too much power. If you want to know, take a multimeter, hook the ground to the negative lead of the battery, and the ground of the multimeter to the positive of the LEDs (probably want the amp at its 10A+ setting so you don't blow the fuse) and you can figure out how many amps they pull. If it's only a couple amps or less, you'll be fine hooking it up to an interior light.
Another idea, twist the switch out, and you should have some wires coming off of it. Test them out like discussed earlier with the multimeter/voltmeter and whichever reads 12 volts, there's your positive.
------------- 87 Astro 4.3L; Eclipse CD5000
88 Bronco 351W on 32x11.5x15 Yokohamas, Clarion Phaze 1 Components.
Home: MTX Thunder8000 in truck box & Parts Express amp.
Posted By: pelirojo
Date Posted: October 26, 2005 at 12:24 PM
I'm wanting to do the same thing on my '06 EX Sedan. however, your post is the most revelant thing I've found. :)
I agree it should be as simple as the EET's have posted. Hook in to the 12volt door switch. Problem is finding a schematic.
Official Honda accessory for this year/model is a constant light when your parking lights are on. Rather, I'd like a door open light.
