Windshield Sprayer LEDs
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=66593
Printed Date: May 15, 2024 at 9:23 AM
Topic: Windshield Sprayer LEDs
Posted By: v-bizzle
Subject: Windshield Sprayer LEDs
Date Posted: November 19, 2005 at 12:46 PM
I just got some windshield sprayer LED's for my '98 Civic HX and i have no clue how to how to hook them up. There is a black and a red wire coming from them and i want to hook them up to a switch. Any help?
Posted By: ff-mike
Date Posted: November 21, 2005 at 3:26 PM
black = ground
red= power
Posted By: ringojam
Date Posted: November 21, 2005 at 8:45 PM
As above butput red to park light + and that will be your switch ------------- Jamaica home of the worlds fastest man.
Posted By: v-bizzle
Date Posted: November 22, 2005 at 12:33 AM
I'm really a noob.......i dont know how to hook the wires to the battery. What do i use to hook it to the battery? And where is the parking light switch?
Posted By: captjimmy15
Date Posted: November 30, 2005 at 11:02 PM
i have a 98 dodge dakoda with 6 wiper LEDs on it, 2 on the hood and 2 in the grill they r wired into the foglights. the other 2 LEDs i have are hooked up to the turn signal lights (ie the right LED flashes when im turning right and left flashes when im going left). currently i have the lights all wired into the preexisting fog light switch so LEDs are on when the fog lighs are( excluding the turning LEDs). so if u want to go that road u can tap the LEDs u want to install in to ur headlighs or something and just add a switch somewhere along the new LED wires. See corny picture for example... NOTE: FRONT FACING LEDs ARE ILLIGAL IN MOST STATES TRUST ME I KNOW =( ------------- CaptJimmy
Posted By: cowboy21
Date Posted: December 07, 2005 at 7:17 AM
for added effect run a 12v+ source to a switch, then to the red wire, ground the black wire to a good grounding spot (ie the screws for your window wiper motor) then u can leave them on with ur headlights off or on, good luck
------------- modest yet effective... ECLIPSE 12", Venom 8"x2, Focal 5 1/2" comp.,Response amps x2 (580WRMS total @ 4Ohms), Pioneer TFT + DVD, good for 148.7dB
