LED vs. Neon
Please state the pros and cons of each.
I was also wondering if LED's spread light out like neons do.
Headunit-KDC-MP928
Front Speakers-OEM
Rear Speakers-OEM
Subwoofer-Kicker L5 12inch
Subwoofer AMP-Kicker KX600.1
I have found with LED kits some of the LEDs will go (not work) and some will still work in the individual LED bar itself. after TIME. wheras IF your NEONs go you wired em wrong.
40 grit has saved my life sometimes =[
wish I ccould edit.
Anyway the kewlest thing about LEDS is the differnt patterns the produce. ( not just ON) Scanning ect. and they give off about the same light if not more depending on the kit you buy.
Im going to put them together myself. I might mount them to plexiglass would that work good? or what do you suggest
Headunit-KDC-MP928
Front Speakers-OEM
Rear Speakers-OEM
pros and cons
LEDs pros- use minimal power comsuption, are directional (so u can aim them at something in particular), much smaller and can be hidden + take up less room, less fragile then neons, much easier to use for custom work
cons- certain colors like red aren't as bright as neons, because of directional beam not so good for lighting a general area
NEON pros- can light bigger areas, can fade brightness, generaly cheaper
cons- use ALOT of power comsuption, generally large in size, can break easy
modest yet effective... ECLIPSE 12", Venom 8"x2, Focal 5 1/2" comp.,Response amps x2 (580WRMS total @ 4Ohms), Pioneer TFT + DVD, good for 148.7dB
