12V Dimmer for LED?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=67261
Printed Date: May 16, 2024 at 4:34 AM
Topic: 12V Dimmer for LED?
Posted By: teeguy79
Subject: 12V Dimmer for LED?
Date Posted: November 29, 2005 at 1:26 PM
Does anyone have a good source for buying a 12V
Dimmer switch for LED rope lighting? I have some
12V rope I'm putting in a bus and would like to
put it in a dimmer switch - a tough item to find...
Posted By: KPierson
Date Posted: November 29, 2005 at 4:55 PM
Have you tried using a potentiometer? You may be able to lower the voltage going to the LEDs and cause them to dim. It depends on how the LEDs are configured inside the rope, though.
------------- Kevin Pierson
Posted By: boyzWidToys
Date Posted: November 29, 2005 at 5:27 PM
you'd need a pwm signal. to blink the lights fast enough that they look dimmer
Posted By: cowboy21
Date Posted: December 07, 2005 at 7:23 AM
i agree with boyswidtoys, leds don't take to dimming very well, they need to flash rather fast at 3/4 potential to make them look dim, sux i know but its one of few downsides to leds
------------- modest yet effective... ECLIPSE 12", Venom 8"x2, Focal 5 1/2" comp.,Response amps x2 (580WRMS total @ 4Ohms), Pioneer TFT + DVD, good for 148.7dB
