2006 Saturn Ion, 12v lights
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=68787
Printed Date: May 06, 2026 at 5:52 PM
Topic: 2006 Saturn Ion, 12v lights
Posted By: boaz
Subject: 2006 Saturn Ion, 12v lights
Date Posted: December 20, 2005 at 6:48 AM
Hi,
I'm looking to install some 12v lights under the front seats of my 2006 Saturn Ion. My question is where would be the easiest/fastest/best place to wire into? Thanks!
Posted By: KarTuneMan
Date Posted: December 20, 2005 at 8:59 AM
Is there something under there you need to see?posted_image
12volts
posted_image
 red (40A), red (30A)
posted_image
posted_image
 pins 37 and 34, BCM C1
posted_image
Ignition dk. blue  +  ign harn or pin 7, BCM C4
Easy to get the power under the seat, make all your connections at the BCM
Posted By: boaz
Date Posted: December 20, 2005 at 11:54 AM
Thanks a million, this'll really help. Not to sound like a newbie, but could you put it all in laymens terms for me (or even some steps to follow)? I've done electrical before but never on a car. Thanks again.
Posted By: bellsracer
Date Posted: January 17, 2006 at 5:15 PM
Yay! Another Saturn! If you have the console with 2 power outlet on it, tap into the rear power outlet for power. This will turn on your lights when your car get's turned on. If you want to turn them on and off at your choice, tap into the front outlet and install a switch.
You know how to take the console apart to get to the wiring, I assume. If not, just PM me or ask me here and I'll help you out.
Ganbatte ne (good luck -or- do your best)
