custom underbody kit
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=70918
Printed Date: May 05, 2026 at 5:03 PM
Topic: custom underbody kit
Posted By: hamesworth
Subject: custom underbody kit
Date Posted: January 16, 2006 at 3:52 PM
how hard would it be to make a custom underbody kit out of led's i mean i have a bunch. but how would i mount them, or get them in a tube so i wouldn't have to worry about water damaging them. also how would i wire the led's in?
-hamesworth-
Posted By: total_overkill
Date Posted: January 17, 2006 at 3:16 PM
Do you have any experience wiring LED's? This I must say is alot of work. Do you know how to program them? make em strobe flash ect? Or do you want them to be just all Bright?
If you want to save the time I would suggest getting a cheap set off Ebay. After saving all the work it will probably work out cheaper for ya. they usually come with a module for strobbing ect. No matter what though when you have em , Either bought or made. I would put extra coats of Clearcoat on them to make em even more waterproof. I have seen these LED bars loose sections of LEDs all the time from water leakage.
40 grit has saved my life sometimes =[
Date Posted: January 17, 2006 at 10:33 PM
well my thing is, that i would cut the end of the led's to give them a wider range and look more as one light, instead of a bunch of little lights.  that's the only thing.  but i don't know how to program them, only how to make them solid.
-hamesworth-
