goodwrench twilight sentinel
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=70944
Printed Date: May 05, 2026 at 3:43 PM
Topic: goodwrench twilight sentinel
Posted By: mechanicmoore
Subject: goodwrench twilight sentinel
Date Posted: January 16, 2006 at 9:58 PM
yes i got his add on from gm.the problem is i cant find the wiring diagram that came with it.gm will not help me on this without buying another one just for the diagram.this is a add on kit for any car or truck.the box has seven wires,red(fused)power wire/black=ground----ok now what?it has a white,yellow,light brown,brown and pink wires.it also has a photo cell at the end of two small black wires.so it can be installed at the glass.if anyone has any info on this i will buy dinner........lol.......Thanks MechanicMoore
P.S. there are no part numbers on this unit....sorry not much to work with,i know.
Posted By: candy&chrome
Date Posted: January 22, 2006 at 4:43 PM
i know what your talking about it's a delay timer for the headlights and an "automatic on" when the sun goes down, i've never actually installed one but my advice is to get a 12 volt light of some sore (fog light) a car battery and a test light fuse every wire with a 10 amp fuse and test it by trial and error if you know red is 12 volt, black is ground then brown should be parklights, the other i'm not sure but i do know that the timed lighting is controled by the activation of a door pin, once the door is opened the lights start to time out because if they didn't the headlights would stay on untill the battery was dead. and the other 2 wires may be for the photo cell itself. if you can take a photo of the unit and i'll see if i can get more info for you
canada's cold eh.
