building led tail lights, 93 Mustang
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=71888
Printed Date: May 05, 2026 at 9:45 PM
Topic: building led tail lights, 93 Mustang
Posted By: mfb_306
Subject: building led tail lights, 93 Mustang
Date Posted: January 31, 2006 at 12:48 AM
I am building these led tail lights for my 93 mustang 5.0 I drew the plans on autocad.I cut the pieces out of lexan to secure the led's to then mount on the inside of my tail lights.Any advice is needed there is a total of 77 10mm led's per side,is that to many and also what is the best way to go about wiring it.
Posted By: firstrax
Date Posted: January 31, 2006 at 9:49 AM
You could simplify things by using one or two Lumileds LXHL-LD3C leds. Use a constant current regulator as shown in the picture.
Posted By: firstrax
Date Posted: January 31, 2006 at 9:50 AM
Forgot the picture.
posted_image
