Neon Hookup
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=72567
Printed Date: May 06, 2026 at 2:34 PM
Topic: Neon Hookup
Posted By: Walkercustoms
Subject: Neon Hookup
Date Posted: February 10, 2006 at 10:09 AM
Ok, this is what I want to do. I got a deal on some Neons and they are going to go on my girls truck. What I want to do is have them come on when the door is open and turn off when the door is shut (like the dome light). I will also want to turn them on when ever I want (driving or sitting still). What do I need to make this possiable?
Wade
Posted By: auex
Date Posted: February 12, 2006 at 8:05 PM
Use a relay and a toggle. Wire relay to activate via ground. Isolate door trigger/triggers and switch inputs from each other.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: coppellstereo
Date Posted: February 13, 2006 at 3:14 PM
quite confusing.
Posted By: auex
Date Posted: February 14, 2006 at 3:31 PM
coppellstereo wrote:
quite confusing.
Not really.
posted_image
Date Posted: February 15, 2006 at 12:35 PM
Thast cool I am going to keep this in mind.  I talked to her and they are th Pipedream LEDs and she likes the little control box that it comes with.  It will let here change the speed and movement of the lights.  Sorry for the mistake but they are LEDs not Neons.
Wade
