Turn signal/brake light won’t work
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=72828
Printed Date: May 06, 2026 at 8:53 PM
Topic: Turn signal/brake light won’t work
Posted By: uhoh
Subject: Turn signal/brake light won’t work
Date Posted: February 14, 2006 at 5:47 PM
I have a 96 Chevy Suburban and my turn signal won't blink nor will my brake light work on the rear left side.  They will blink really fast in the front left and on my dashboard.  I know that normally that means that you have a blown bulb but I have replaced the bulbs, the plate that the bulbs go into, and the flasher relay and I still have this problem.  Is there anything else that i can do?  Thanks.
Posted By: fingaz22
Date Posted: February 14, 2006 at 6:47 PM
check the ground for that light assembly first. if you clean and know the ground is good. suspect the multi function switch for the running lights in the steering column. that is what controls the turn & brake lights. it's the unit the turn signal lever is mounted to.
but really check the ground because usally both sides won't work if that was malfunctioning. but don't discount it though.
CHECK THE GROUNDS!!!!!!!!!!!!!!!!!!!!!
JUST ONE MORE AMP!!!
hu,alpine cva 1005/dva 5205
sound processor,symmetry(first one).
sub amp,power 1000 the terminator.(1992).
subs,spl comp dual 1 ohms.
punch 150hd on a 10" ev.
alotofhighs
Posted By: uhoh
Date Posted: February 15, 2006 at 7:29 AM
thanks.  where would the ground for the light assembly be located at?
