neons, led switch wiring?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=77316
Printed Date: March 15, 2026 at 4:04 PM
Topic: neons, led switch wiring?
Posted By: nolan11
Subject: neons, led switch wiring?
Date Posted: May 05, 2006 at 9:47 AM
I have a blue neon lights under each dash and light up pedals.
I had a standard toggle switch controling both the neon lights and pedals.
I bought a LED light up switch from Advanced Auto that lights up when switched on looks like this with the 3 prongs....one says POS, middle one says ACC bottom says NEG.
Ever since i hooked it up i keep blowing a 30A fuse. My question is the fuse to small of Amps or my wiring could be wrong. I was using a 30A fuse before and everything was fine.
Now the fuse is blowing. Since the switch lights up do i need a bigger amp fuse? I wouldnt think I would.
So to save some time can someone please tell me the basic way the wiring should be hooked up?
I just want the switch, neon lights and pedals to light up when i turn on the switch.
Bruce
it looks like this posted_image
Posted By: xtremej
Date Posted: May 05, 2006 at 2:38 PM
Does the fuse blow as soon as you hook up the wires? Or when you switch them on.
Posted By: nolan11
Date Posted: May 06, 2006 at 9:14 AM
the fuse blows when i turn the switch on.
thanks
Posted By: KPierson
Date Posted: May 06, 2006 at 11:15 AM
First of all, your fuse is WAY too big.  You should have a 5A on there, if you are just running two neon tubes.  You could probably get away with a 3A if you could find one.
The POS terminal should go to a fused 12VDC source.  The NEG terminal should go to ground.
The ACC terminal should go to the + of your neon transmormer, and the - of your neon transformer needs to go to ground.
Kevin Pierson
Posted By: crcustoms45
Date Posted: May 29, 2006 at 4:32 PM
i agree.  remember you are adding a light to the circuit.  the switch will still work without the (-) wire connected, it is only for the light on switch.
Chris
CRCustoms
