connecting alarm to flash turn signals
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=79520
Printed Date: June 09, 2024 at 9:30 AM
Topic: connecting alarm to flash turn signals
Posted By: flyimages
Subject: connecting alarm to flash turn signals
Date Posted: June 23, 2006 at 3:32 PM
trying to connect my alarm's negative parking light output to the L+R turn signals to flash. 2001 Toyota Celica GTS my wiring diagram: https://www.the12volt.com/installbay/forum_posts.asp?tid=6902
Posted By: stealthone
Date Posted: July 03, 2006 at 12:45 PM
I do this with police motorcycles.
1. Find your hazard flasher. Unplug it.
2. Using an ohm meter, take a reading from each of the wires to ground. One should be infinite, the other should be near to short (~10 ohms).
3. Tie your alarm output into the one that is near to shorted.
4. Test your alarm flasher.
5. Reinstall flasher.
You are done.
Posted By: ringojam
Date Posted: July 03, 2006 at 8:36 PM
You can also connect at kick panel wires running to the rear of the car,make shure you use diodes to isolate each out put .If yr alarm has two seperate park light wires you dont need to isolate.
------------- Jamaica home of the worlds fastest man.
