easy lighting method
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=91728
Printed Date: May 14, 2026 at 12:00 PM
Topic: easy lighting method
Posted By: speakermakers
Subject: easy lighting method
Date Posted: March 15, 2007 at 1:09 AM
Most of us here have thought about doing this, or seen it done, or even tried it. It has been around for a while, it’s not new. Having said that I still don’t see enough of it around. I really like this look. Its cheep, fast to do, and I get very positive feed back every time I do it. I have a few tips for those who have not tried it yet, and I hope to encourage those who have considered doing this to try it.
posted_image
I have encountered a number of good installers that have tried this bent and lit plexi rod method and had a bad experience because they did not get the brightness and consistency of color that they were looking for. Like I have said I have had very good experiences with this and I believe that I know why. Before I decide to commit to this lighting theme in a vehicle I first consider a few things.
1.     will the rod be viewed an angle or strait on or both?
2.     Will the rod be in a place of darkness where the lighting effect will be vivid?
3.     If the rod will be out in the light will the rod look out of place if it is frosted white?
4.     Can the rod serve some other purpose other than light?
5.
In the vehicle pictured above every lit rod-line serves has a function other than just light. I believe that this obvious functionality helps keep the lighting effect from looking to cheesy. On the center console the rod (that whole top piece is one rod 5 ft long) holds the remote. On the door the rods serve as a grill for the 8. on the kicks the rod continues the line from the door speaker to form a visual connection across the speaker system.
posted_image
In the back of this same truck I used 1” rods to help support the 15” wide screen on the ceiling (not really but it looks that way). Notice that the rods on the left side are mounted to the C pillar and the rods on the right are mounted to the D pillar, Symmetrical is way over done. The rods in the back are always in the shadows and look great when lit, so I did not frost them. The rods on the front doors are in direct sun light when the doors are opened during the day and consequently you can barley see the color come through the rods.
posted_image
This still works for this install because the rods look good unlit and still serve the function of speaker grill.
posted_image
The rods definitely add something to this install, even with no light.
posted_image
On this install the customer was going for the jukebox-neon beer sign kind of look to go with the Irish green theme. The rods where in direct sunlight all the time. I sanded the backs of the rods with 80 grit on a 3” DA. The rods look white when they are turned off. This white frosting makes the light kick off of the tubes and appears much brighter and uniform along the rod length.
On this install the rods are also always in direct sun light. This is a system that we did for Infineon Raceway a Toyota sponsored NASCAR race track. The truck sits out near the track in the sun all day. The rods here represent wire running through the PS3, and they give three separate effects.
1.     Viewers don’t really stand directly in front of the door that this project is mounted on.
2.     The rods look really good even with no colored light.
3.     I put red LEDs in one side and blue LEDs on the other side of every rod. This way the color changes depending on where you stand. And it reflects nicely off of the paint
posted_image
Inside Cody used the same colors on larger rods to make a speaker grill. Viewers always see these rods from an angle and they are in the dark. Consequently they are always bright.
posted_image
And here I used the plexi rod to hide the wiring on these amps.
posted_image
posted_image
The rod is transparent but it defuses the light and makes it real hard to see the RCAs, speaker wire, and power wire running into these amps. Also notice that the rod dives right into the painted amp rack. You can use a paddle bit the same size as the rod to drill right into fiberglass and you wont be able to see through the rod like you would think.
Heat any size rod up to 1” with a heat gun and bend to desired angle when soft enough.
Plastic stays flexible for several minuets.
Don’t get heat gun to close or the plastic will bubble.
Don’t worry about small bubbles, they sometimes look cool.
Some installers prefer to build jigs to hold the rods in perfect form while they cool.
I prefer to bend by hand and spray with glass cleaner to speed up the cooling when I get the angle right. You can always heat it up again.
The LED dose not have to be right up against the end of the rod. On several of my projects the LED is set back a couple of inches (for mounting purposes), and it looks the same.
Plug all of your LEDs into your 12V drill battery and test your lighting arrangement before you commit.
Cheap LEDs from SoundQuest (Stinger) seem to work as good as any. They are available at every store that carries Stinger.
I want to see some pics of what other people are doing with this. Post some replies with some info on your experiences.
Posted By: killer sonata
Date Posted: March 16, 2007 at 5:40 AM
How far away from the plexi do you hold the heat gun while warming it up?
do you use any type of heat gun attachment?
approximately how long do you typically apply heat to the plexi?
"People with mullets live 40% longer"   - Ricky Bobby
Posted By: implodejl
Date Posted: March 17, 2007 at 12:08 PM
dude this is really cool. I keep coming back to look at these pictures because I want to run 3 or 4 tubes across my subwoofer box as a grill. could you do a little DIY write up for how you actually did this?
Posted By: 99 2envy
Date Posted: March 19, 2007 at 7:43 PM
Speakermakers, very nice. I realy enjoy your work
Date Posted: March 24, 2007 at 12:42 AM
Date Posted: April 18, 2007 at 3:47 PM
Yeah, Please let us know how you did this!
Date Posted: April 22, 2007 at 6:51 PM
I hold the heat gun about 5-7” away from the plexi. If I see bubbles start to appear I stop and let the plexi cool all the way down, and then start over. Like I said some bubbles don’t look bad but a bunch looks real bad. I have found that holding the heat gun farther away and continuing to heat the joint doesn’t really work because of the way that heat travels through plexi. Heat will build up in one spot and then gradually spread out in order to dissipate its self. If you over heat one spot you must stop because that spot will continue to over heat at a faster rate than the rest of the plastic.You will notice when you try heating a rod that once you have heated the plexi enough to bend it that it will continue to get even softer after you have removed the heat. This is because as the heat dissipates its self it spreads more evenly through out the rod even as it cools. This all sounds tricky but the reality is that its quite simple to do. Just pick up some plexi rod (its cheep) and try it.
Its also worth mentioning that I have tried many special tips and expensive regulated guns and they don’t do anything for you. I use a good old 25$ Wagner.
Recently I have come a cross half round plexi rod. This stuff bends nicely without loosing its profile and it lays flat. Laying flat has many advantages when it comes to mounting.
I found this stuff for $3.60 for a 6 foot section at www.tapplastics.com
posted_image
Posted By: deonjones
Date Posted: May 09, 2007 at 12:30 AM
hi, i love what you have done. i am very new to this kinda work and i was just wondering what kinda LED the stingers are? are they just a small LED light such as ones that are on alarm systems that flash or are they like a small tourch like thing that sprays the light? thanx
Posted By: NowYaKnow
Date Posted: May 10, 2007 at 4:54 PM
I don't use this method much, but I do have some random tips. Placing the rods in the oven (on your moms best cooking sheet) will evenly heat the entire rod. This is good if your going for a complex shape. Like with the gun if you turn the heat up too much yes it will bubble.
Next tip depending on the rod diameter you can drill a shallow hole in the end and insert the LED. This is basically the same steps people were using to make the DIY angel eyes after the BMW's came out with them.
Mike
Date Posted: May 10, 2007 at 7:00 PM
sorry guys so is there any other name for the LEDs u guys r using? and also the plexi rod?
i went around yesterday looking of some of the stuff but all the people i talked to didn't know what it was.
Automotive Electrical Accessory Fitter
______________________________
1x TA3404
1x TA81001
1x T9515-44
1x TS-C160R
1x TS-D691S
1x AVHP-5950DVD
Date Posted: May 10, 2007 at 7:25 PM
also if u have any websites that have info on them can u post them please.posted_image
1x TA3404
1x TA81001
1x T9515-44
1x TS-C160R
1x TS-D691S
1x AVHP-5950DVD
Date Posted: May 11, 2007 at 12:59 AM
Great tip on the oven heating Mike! I have used an oven for heating sheets in the past and it works great for all types of acrylic. I recommend using aluminum foil on top of a cookie sheet with the plastic on top of that and setting the heat at its lowest setting. The plastic will release some fumes and odor but nothing to bad. It wont stink up your kitchen permanently but be ready to explain to your woman. That’s the voice of experience! Also you can handle the plastic with a couple of clean rags. The plastic will only be 175-200 degrees and will take 1-2 minuets to heat.
Posted By: bballguy162006
Date Posted: June 19, 2007 at 3:02 PM
That is very cool speakermakers, I have never seen that before.  I would like to try that in one of my upcoming installs, what method do you use to secure the plexi rods to the fglass?
Date Posted: June 29, 2007 at 1:10 AM
I drilled a hole into the fiberglass with a paddle bit that was the same size as the plexi rod and super glued it into place. You would think that you could see through the clear plexi and into the hole but you cant. It’s a trip. Your line of sight just ends were the rod dives into the fiberglass. Every time!
Posted By: jurb
Date Posted: July 11, 2007 at 10:57 AM
Can you drill into the end of the plexiglass tube to mount the led?  I want to make the sub grills so the LEDs are going to be in the box and it would be easiest to mount if I drilled out the end of the tube and glued it in there although it may make uneven lighting.  Thoughts?
Date Posted: July 11, 2007 at 11:04 PM
Sure I have done this many times and it works fine. The source of the light can be obvious doing it this way but that can look cool to. Post pics please!
Posted By: pjpatel
Date Posted: July 24, 2007 at 10:41 AM
what about the fuses. Where do you get the power from or where else aside from the cigarette lighter would i get the power. i blew out a fuse doing so from the 12v power.
Posted By: troy_audi0
Date Posted: August 23, 2007 at 6:42 PM
nice ..
love LED's & Plexi..
sweet wrightup..
Troy
Kia Spec 5
Alpine IAW-505
JL HD600/4
JL HD 750/1
Alpine SPX-17Pro
RE Audio SE10
Tsunami Install Parts
Posted By: jl.w7
Date Posted: October 05, 2007 at 11:02 AM
that is so sweet!! Im going to try that. Where can u get the plexi rods??
MECP Certified
(2)Infinity 3.5" 3012CF
(2)Infinity 6x9 9612I
(1)Sony CDXGT710
(2)MTX TC510 and,
A load of dynamat!
1982 Chevy Cavalier
