drl’s, 93 cavalier
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=93539
Printed Date: May 16, 2024 at 10:59 AM
Topic: drl’s, 93 cavalier
Posted By: spaceman74
Subject: drl’s, 93 cavalier
Date Posted: May 02, 2007 at 8:33 AM
I bought a 93 cavalier from the U.S and I will bringing it to Canada. But because its a U.S model, it doesnt have DRL's. In order to pass the Federal Inspection here, I have to have them. What do I need to do to have my hadlights come on when the key is turned? Thanx
------------- Keep working! Millions on welfare depend on you.
Posted By: bellsracer
Date Posted: May 02, 2007 at 5:51 PM
I would tap into the ignition wire and bring that to a relay that will turn on the headlights. Relay Connections 30: Headlight control wire (a yellow or tan wire at the headlight switch) 85: ignition wire (pink wire in the ignition harness) don't forget to fuse 86: ground 87: 12volt source (fused) 87a: leave empty or cap off That should take care of DRL problem. Ganbatte ne! ------------- Never send your ducks to eagle school.
Posted By: sparkie
Date Posted: May 02, 2007 at 6:48 PM
GM does sell a kit to add DRL to any vehicle. It performs exactly like the car was built with it.
------------- sparky
Date Posted: May 03, 2007 at 11:29 AM
Well, I will chack GM but I will be prepared to take in the ass, cause it will probably be alot of $$$ :)
Date Posted: May 03, 2007 at 11:46 AM
No such kit available from GM.
Date Posted: May 03, 2007 at 11:47 AM
Bellsracer, what type of relay and fuse size please?
Date Posted: May 04, 2007 at 12:10 AM
Use a 15 amp fuse and your relay is a standard automotive relay. The relays will go by various names, but the most common names are Bosch or SPDT. Prices will vary from $5 - $15 US depending on where you get it from, and whether or not it comes with a harness pack. If it doesn't come with a harness pack you'll need to get a hold of female disconnect terminals for your wiring. Ganbatte ne! ------------- Never send your ducks to eagle school.
