what’s wrong with my system?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=102393
Printed Date: May 10, 2024 at 3:21 PM
Topic: what’s wrong with my system?
Posted By: eaks
Subject: what’s wrong with my system?
Date Posted: February 21, 2008 at 12:00 AM
Hey guys I'm in need of help!
My setup:
- alpine ida-x001 headunit
- alpine mrd-m1005 amp
- alpine type x sub (10" with alpine box)
My problem:
I just put this system back in my car for spring! I hook everything up and it sounds ok but not much bass at all! I change the gain on the amp to 50% and try again sounds a bit louder but then I turn up the volume and the the sub just stops all together check my amp and it is flashing "cur" so I restart my deck and the bass comes on for a second then stops again (same error on amp) so I restart the deck again and turn the volume on and I can hear the sub a bit turn it up and I can def hear it (but its not to loud) turn up my sub volume and it cuts out again!
So I call alpine and said I checked everything I could think of and he notifies me that the error is becuse the output impedance is too low (short)! So I go out side and measure the resistance off the sub 1.7 ohm (which is right dual voice coils (4 ohm each) wired in parellel to give me 2 ohm! So I have no idea where the problem is!
What do you guys think?
Posted By: eaks
Date Posted: February 21, 2008 at 12:08 AM
And I also did try with my gain turned down (4v)!
Pretty much right now I can't even tell if the sub is working becuse if it is then its so low that the bass from my 6x9s and 6.5s are just as loud(even with the bass knob oh their amp(mtx 200 watt rms) and the bass turned all the way down at the deck)!!
So please help me out!
Posted By: audioman2007
Date Posted: February 21, 2008 at 2:54 PM
Is your amp a mono block? Also, do you have the amp running at a impedence it can handle? It just sounds like something isnt connected correctly. Obviously your power, ground, and remote turn on wires are correct. But I would double check how you have the sub wired to the amp. Check to see if there is any place where the positive and negative speaker wires are touching eachother. This will cause a spike. If you take your speaker ends and touch them together, they will cause your amp to shut off. But this will only start doing that when the headunit gets to a certain volume. Also check to make sure you have the amp running at 2 ohm. If you have it wired wrong, you could be running it lower than it can handle, thus causing your amp to go into "protect" mode. Once again, the amp will only do that once the volume is at a certain point.
Posted By: eaks
Date Posted: February 21, 2008 at 6:22 PM
My amp is wired fine as well as my sub! I didn't change anything in my system since last year and it worked fine! Amp is made to run 700watt rms @2 ohm at 12v or 1000watt rms @2 ohm at 14.4v so it should be fine! I did check for continuity through the wires and they weren't touching!
Anyone?
Posted By: i am an idiot
Date Posted: February 21, 2008 at 8:08 PM
Hey Audioman, you gotta love it.
Posted By: furflier
It is possible that the tennsil leads on the sub could be hitting the basket when the bass hits.
Date Posted: February 21, 2008 at 8:46 PM
gotta love what? Anyways, is there a way you can use another amp to test everything? If you pull out that amp and put another in its place just to start narrowing the possibilities down. If the problem continues, you then know your amp is fine. Then its either the wiring, headunit, or subs. Then from their, test something else. It could be your RCA's and maybe even your headunit. I would just start testing each part of your system and narrowing it down.
Posted By: eaks
Date Posted: February 21, 2008 at 11:06 PM
What basket? i dont really understand what your saying..
Date Posted: February 21, 2008 at 11:17 PM
tensil lead = the wires that go from the terminals to the cone of the speaker. Basket = the metal frame of the speaker.
Posted By: mazzasec
Date Posted: February 21, 2008 at 11:55 PM
or just try a diffrent sub borrow your friends for like 2 seconds and see if the amp goes to that mode with his sub as well then you know its the amp not the sub
Posted By: aznboi3644
Date Posted: February 22, 2008 at 12:03 AM
what is the voltage at the amp when the system shuts off??
My friend has the same setup but with two amps and two 12 inch Type X's...works fine. I've even had one of those amps wired to 1 ohm and it works fine if set up carefully.
Posted By: dustysnakes
Date Posted: March 19, 2008 at 1:02 AM
yeah sounds like the voice coil may be getting a dead short at excursion to me. 1.7 isnt uncommon at one wired for 2 ohms it will fluctuate a bit as the coil moves constantly. try runing the amp to any old piece of junk speaker ... even a house speaker or somthing higher than 2 ohms and see if that amp still goes into protect if it doesnt youve found your problem.
------------- keep it greasy
