upgrading alternator
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=102580
Printed Date: May 14, 2024 at 6:33 AM
Topic: upgrading alternator
Posted By: looknup
Subject: upgrading alternator
Date Posted: February 26, 2008 at 6:14 PM
So, on my quest to find a high output alternator for my vehicle I run into the Advance Auto associate. He tells me that upgrading my alternator can/will fry my ecu. I thought that was a little weird. Unless a higher output alternator puts out more than 14.8 volts, there shouldn't be a problem should there?
Next stop, Mr. alternator repairman. He tells me the same thing.
Why would a higher output alternator have any effect on my ecu? Alternators should all run at the same rated voltages right? Someone please clarify this for me.
Thank you.
Posted By: haemphyst
Date Posted: February 26, 2008 at 9:16 PM
No... Unless the alternatoris wired incorrectly, and putting out more (technically PRODUCING A HIGHER) voltage than it should, it will not fry anything.
The devices will still pull exactly the same amount of current, and dissipate the same amount of power, whether you have the stock alternator or a 1000A alternator.
Saying a HO alternator will fry anything is like saying adding a second battery in parallel will too... It won't happen. Period. All you are doing is providing a source of higher current, not voltage.
------------- It all reminds me of something that Molière once said to Guy de Maupassant at a café in Vienna: "That's nice. You should write it down."
Posted By: ferretvw
Date Posted: February 26, 2008 at 9:27 PM
To add a little to what Haem said, you have to think of an alternator like a pool of available current. It does not "send" all its current to a particular circuit, a circuit will only draw the current it needs so like he said everything will still be getting the exact same amount of power (as long as the alternator is putting out the correct voltage) as it was before and your current available (to run lights, amps etc) goes up.
------------- 2008 Scion xB
Pioneer AVIC-D3
RF 3Sixty.2 sound processor
Stock speakers (for now ;))
Posted By: looknup
Date Posted: February 26, 2008 at 11:28 PM
I thought it was weird myself.. I thought I knew how alternators worked until I heard these guys.. then I was confused. But there was something in the back of my mind that seemed weird to me. None of what they said made sense...
And one guy is a alternator repairman! wth!
Posted By: italian_virus
Date Posted: February 27, 2008 at 12:03 AM
I am also on the same quest as looknup
i drive a 95 civic and i was just curious to know if anyone knows of any good brands that make High Output Alternators?
I was going to purchase a Load Alternator Boss 135A for about $215
good deal??
i also heard stinger makes good alternators for audio..
keep in mind this is more for audio purposes and obviously to make the car run better =P
Suggestions anyone?, any help would be greatly appreciated.
Date Posted: February 27, 2008 at 1:25 PM
Having HAD a Load Boss, I can tell you that it was a decent alternator... WHILE IT LASTED! Call HOAlternators... I'll try to find the info for you. It will const you more (A LOT more, sadly) but it is a FAR better alternator, with a much better (IN WRITING) warranty.
:::::EDIT:::::
Here ya go...------------- It all reminds me of something that Molière once said to Guy de Maupassant at a café in Vienna: "That's nice. You should write it down."
Date Posted: February 27, 2008 at 10:21 PM
:::::EDIT:::::
Here ya go...
realllyyy ??? okk then thanks.. yah i dont mind paying decent money for something that is good quality & that will last...
now there are two different types of alternators offered to me
they are
86423 - Denso - 170A
40639 - Mitsubishi - Call of output
( since its 11:20PM @ night i will try and make the call this week)
These two are the only ones offered, so which one out of these do you gentlemen recommend??
Posted By: sedate
Date Posted: February 28, 2008 at 7:29 PM
I mean - I always get beat over the head on this board for saying this - but are u sure u need a HO alt? You haven't indicated your battery/engine wiring situation - the Big Three and a Deep Cycle are the appropriate places to begin - not an HO alt. Not shure about heamph's recommendations, but keep in mind that rewound alternators do NOT produce full voltage at idle - the power band of the alt changes and therefore they tend to produce less than ~12v at idle - this is disasterous for your battery and hungry, hungry amplifiers. I would explore this solution as a LAST resort - and - this is a place where you want to spend all the $$$ ur quoted - do NOT cheap out on this item. Post back with: 1)what are your power symptoms - WHY do you want an HO alt? 2)what have you done to alleviate these symptoms so far ------------- "I'm finished!" - Daniel Plainview
Date Posted: February 28, 2008 at 7:45 PM
Well, James is right on.... MANY "HO" alternators are simply re-wound OEMs, and it is true that they will NOT put out 12V at idle.
The HOAlternators are not as simple as being re-wound, they are DESIGNED FROM THE GROUND UP to be HO from idle to red-line. As an example, the one I have in my car (and I have a current meter in my dash for JUST this purpose) makes 13.6V @ idle, and over 80A, without even revving the engine! It is rated 200A cold, and 170A hot. The differences between the Load Boss (which I still have - in pieces - in my garage), the OEM, and the HO piece are all painfully obvious. The HO gear has noticeably heavier stator windings, an overdrive pulley, a larger stator frame, REAL ball-bearings, not bronze bushings. Good product, and built and tested FOR your order. I never would have paid the money I did (for the HO) for anything with a Load Boss badge on it!
The extra money GETS you a genuine HO product, fully capable of doing what it says it'll do!
As far as the one you need? It's going to depend on what one is there right now. If you presently have a Denso, you can't replace it with a Mitsu, and veecie-versa... Go to the dealer with your VIN, and they'll be able to tell you which it is!
Date Posted: March 03, 2008 at 3:21 AM
Ahh ic ic ok fair enough i will check it out
I should also mention that when i purchase the alternator i am not getting a rewound one, BRAND NEW is what i am aiming for.
hehe
sedate wrote:
Post back with:
Well i have already upgraded the Big Three's and when i do my tune up i am going to put in a new deep cycle battery(not sure on the brand yet). The reason i want to change the alternator is because i have to change my water pump/timing belt/tensioner so since i am already there i might as well change it. The alternator & battery are stock and my car is a 1995 so its been 13 years.
Plus i already have a nice 4 channel Rockford fosgate i am waiting to connect..
Its more for sound clarity & to make the car run smooth
Posted By: twobig86
Date Posted: March 03, 2008 at 8:57 AM
Hey haemphyst I have been trying to call the HO alternator 1-866-446-8878 and I just cant get through. Im calling from Canada and it is saying that the call cannot be completed as dialed. Any chance you could quickly dial that number and see if it rings from the states? I tried emailing them and also posting on their forum. Its been over 2 weeks and I still havnt heard anything. I think I saw a local number somewhere on their site but I didnt want to have to call long distance like that. Just wondering if its something to do with my phone or theirs. Anyone have any other suggestions for high output alternators for a 93 honda civic SI - I would settle for a 200 amp alternator BUT I would prefer 250 - 300, if you search my name you will find a post where haemphyst calculated the draw from my audio equipment - it was 210 amps by itself. If anyone lives in Canada and could also just try that number and see if it rings for you I would greatly appriciate it. 1-866-446-8878
Date Posted: March 03, 2008 at 10:55 AM
1-866-446-8878
I have also tried to contact them, they still have not responded to me either. I hope you already did the Big Three's and upgrade your battery before you do this, as you can see i have already been lectured about it =P.
Date Posted: March 03, 2008 at 11:20 AM
Btw twobig86
i have also found this site for the deep cycle
Battery
Posted By: twobig86
Date Posted: March 03, 2008 at 12:04 PM
I already purchased 2 optima red tops and will have the big 3 done when the alternator goes in. system will also no be installed until all that is completed.
Let me know if you get contacted. Did you email or phone them...im beginning to think that unless you phone them you wont get far. though as I said phoning from my house doesnt seem to work.
Date Posted: March 03, 2008 at 12:28 PM
I tried both and got no response, i am from Canada as well so yah we are in the same boat lol.
Now you said you purchased the Optima Red Tops... yours is a 93 Si,
did you get the 25/75 or 34/78 ??
I am curious to know because i have a 95 si and i wanted to purchase a deep cycle and i was not sure on which one to purchase.
Posted By: twobig86
Date Posted: March 03, 2008 at 6:34 PM
34/78 - I originally purchased the 25/75 however then I realized that in the 93 si both the smaller 25/75 and the bigger 34/78 would not fit in the stock battery location. So im going to have my batteries in the trunk. May present a problem with a HO alternator...Ill have to work that out. Before you spend the cash id recommend checking out how much space you have under the hood.
Date Posted: March 04, 2008 at 1:02 PM
HMm but when you go to that site i showed you, you type in the make and model of the car, and it brings up the batteries for it... so i am not sure how it would not fit...
Posted By: twobig86
Date Posted: March 04, 2008 at 9:16 PM
Can you show me the direct link to the page. Cause im telling you you cannot fit either of those 2 batteries into the stock battery location on a 93 civic si the optimas are too wide. im interested anyways in seeing if they say that it will fit.
Date Posted: March 06, 2008 at 7:29 PM
well i just went to a performance shop in Toronto, & they told me they can order and Optima 51 series deep cycle battery, that will fit under my hood no problem.. he says $210 + Tax.. so.. if your located anywhere near there i can give you their # and you can talk to them..
Posted By: twobig86
Date Posted: March 08, 2008 at 4:59 PM
I live in ottawa but i had both the smaller red optima and the bigger one and they just wont fit in the 93 civic under the hood. The 95 might be different let me know if it works out
Posted By: sedate
Date Posted: March 08, 2008 at 11:21 PM
I think kinetik makes a battery specifically for the civic.
