rca cables
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=103284
Printed Date: May 14, 2024 at 12:39 AM
Topic: rca cables
Posted By: jrockc02
Subject: rca cables
Date Posted: March 21, 2008 at 9:30 AM
looking to replace rca's what is better stinger,monster, or any other brand
------------- jerad
Posted By: skee-weezy
Date Posted: March 21, 2008 at 9:38 AM
best rcas i have worked with have been tsumani and jl audio... they are quite.. and don't fail often... monster are pretty good too... sometimes the tolerances on their cable are so tight the ends have to be pryed from the amp though...
------------- there can be only one.......
Posted By: jrockc02
Date Posted: March 21, 2008 at 9:56 AM
thanks the ones that are in my car know are making my speakers hum someone said that i should replace the rca' s and i looked at them and they looked kind of weak ------------- jerad
Posted By: coppellstereo
Date Posted: March 21, 2008 at 12:01 PM
Turn your system on and then unplug the RCAs at the amp and see if the humming goes away.
Posted By: jrockc02
Date Posted: March 21, 2008 at 12:21 PM
it went away i unplugged the other day because it was getting on my nerves i just plugged it back in yesterday and it started doing it again ------------- jerad
Posted By: StealthEs
Date Posted: March 21, 2008 at 12:58 PM
I use a ton of the JL audio ones(the blue ones).
------------- Cris
Posted By: spookiestylez
Date Posted: March 21, 2008 at 1:36 PM
i use tsumani alot too, but im very fond of the JL Audio, and the Stinger Expert rca cables. I use stinger experts in my setup.
Cheers
------------- RTFM
Posted By: jrockc02
Date Posted: March 21, 2008 at 2:42 PM
is there a difference between stinger expert and stinger pro or is it the same
------------- jerad
Posted By: i am an idiot
Date Posted: March 21, 2008 at 4:49 PM
Do you have a Pioneer Radio?
Posted By: dragon51
Date Posted: March 21, 2008 at 7:58 PM
I have never had any problem with the cheap radio shack ones' yea but I want twisted shiled bla bla bla ones. Ok Split the Radio shack ones use a drill and twist them together ziptie down the line wrap with tinfoil, cover with wire loom twisted and shilded. Really there is no need for it. If your able to find the higer dollar ones for CHEAP just be make sure you keep them away from the power wire and routing them under the driver side wire mess. However once in a great while do you ever have to run the high dollar stuff. But that is do to routing the cable most of the time.
Posted By: DYohn
Date Posted: March 22, 2008 at 11:52 AM
Wire is wire. Use decent quality cables and you will be fine. The brand does not matter. ------------- Support the12volt.com
Posted By: jrockc02
Date Posted: March 25, 2008 at 8:04 AM
thanks for everyones input i went and changed them out with ones made by dblink really reasonble i got a 20' set $15 and a 3' set for $3 seem to be working well and made a few other adjustments as well thank you ------------- jerad
Posted By: audiocableguy
Date Posted: March 25, 2008 at 2:16 PM
This has always been a divided subject. I try to guage the quality of supplies to the customer's budget. The cheap stuff does work as good as anything else. The average customer's perception is something else.
On a $3K install I expect to see $20 RCA cables used and not $5 Radio Shack marked up. Nicely finished RCA's with shiny or twisted pair cable looks professional and adds a bit of bling.
It's like going to a higher end restaurant that uses plastic cups. A level of expectation.
On the other hand if a customer insists on highend interconnects, I am in business to make money. They have read the Monster propaganda and believe there will be a huge difference, Fine. I do believe Monster is truely BS.
