2000 silverado, 2005 toureg
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=105235
Printed Date: May 15, 2024 at 6:15 PM
Topic: 2000 silverado, 2005 toureg
Posted By: TheDouche
Subject: 2000 silverado, 2005 toureg
Date Posted: June 03, 2008 at 11:49 PM
ok so this is two projects i got going i need some advice for.
first off i have a 2000 silverado thats getting a sunroof installed and was wondering if it would be a waste of money to dynamat the roof?(i figured it would keep the temp down and maybe help later with sound)
second i have a 2005 toureg thats getting a sub installed into it(my buddies). they wanted to keep the factory radio and stuff just add a sub. im gunna need to use a line output converter no? could you give me any heads up on how to do this. ive never really kept a factory radio so it will be a little new to me on how to get the rcas in
Posted By: mad550
Date Posted: June 04, 2008 at 5:57 AM
Be careful with that Touareg as they use CANbus with the factory deck, I'd suggest an LC6 audio control for the line out conversion, it'll even give you sub out. The silverado we don't have here but dynamating is always a good thing to have for road noise damping but won't really effect heat in the 4WD (SUV for you americans). LOL
------------- WOW Sight and Sound
Maroochydore
Nothing is impossible!
Do it right the first time or don't do it at all.
Date Posted: June 04, 2008 at 10:48 AM
would dynamat on the roof be a waste though?
Posted By: boogeyman
Date Posted: June 04, 2008 at 6:46 PM
I donbt think it would be a waste, at the least it would give you peace of mind.
Date Posted: June 04, 2008 at 9:08 PM
true true. doesnt dynamat have some stuff for heat as well to top it off or is it just better to run the extreme and were good?
as far as the Line converter goes how do they work exactly? and whats the word with CAN? will i run into big problems with it?
Posted By: KarTuneMan
Date Posted: June 05, 2008 at 9:45 AM
Controller Area Network (CAN or CAN-bus) is a computer network protocol and bus standard designed to allow microcontrollers and devices to communicate with each other and without a host computer. -------------
Date Posted: June 07, 2008 at 1:33 AM
ok so i should be good on the tourage if i used a LC6 to just add bass to a all factory car? ive never done a all factory car. i usually install an after market head unit so this is a little new to me.
Posted By: dwarren
Date Posted: June 07, 2008 at 1:39 AM
Remember that the speakers are electronically crossed over in the amp, so be sure either pick a mid woofer lead or you may need to sum all of the leads. I don't recall. Is the rest of the truck dynamatted? There are pros and cons that must be weighed here. Price to performance/outcome. I think it would make a difference in road noise, but how much, sort of a diminished returns situation. However since the headliner may be down it would be an ideal time to do it. Does the sound level in a V8 truck really matter after all? -------------
Date Posted: June 07, 2008 at 6:47 PM
actually i like the sound of the v8 its just the road noise and wind noise i hate. thats why i wanna put the dynamat in. on the roof i figured since its already down and all why not? but i just wanted to make sure.
so how does a line converter work exactly? will it load the headunit amp down? like change the impediance?
so as far as wiring up just jack one of the mid/sub wires and convert it over in the line converter? sounds easy enough im just hesitant cause ive never really done it before
thanks for all your guys help
