dual battery in 99 grand am l4
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=105740
Printed Date: May 14, 2024 at 4:35 PM
Topic: dual battery in 99 grand am l4
Posted By: LqDFx
Subject: dual battery in 99 grand am l4
Date Posted: June 27, 2008 at 3:22 PM
I need some help with a dual battery setup in a 99 Grand AM L4. I need to find an alt. that is bigger than the stock and I am having no luck. Then once I have that I am going to get two new identical batteries for the car. What else do I need to do besides wire them in parallel? Do I need to upgrade the wiring on the first battery under the hood? Can I use the 4ga that I have currently in the car for the amps?
Do I really need to go with a dual battery for my system anyway? I am running 2 amps with a draw of 60 amps, so I am sure that the 90 amp alt is not doing the job there.
Sony XAV-A1 HU, RF P4004 AMP, RF P3001 AMP, 2 RF 10" P1S410 Subs, LA S2.35.2 Dash Speakers, LA S2.525.2 Door Speakers, RF FRC3268 Rear Speakers
Posted By: jar754
Date Posted: June 27, 2008 at 5:41 PM
4 gauge is fine for the amps, do a search and enter upgrade the big 3
Posted By: still_walkin
Date Posted: June 29, 2008 at 7:26 AM
i dont think you need a second battery unless you are going to listen to your radio with the car off for a long period of time. and two batteries is a pain because you have to buy two new ones because they must be likeness of charge and age. do the bige three and bigger battery and you should be good
1993 sdv
Alpine 4x6 6x9 5 1/4 swr-10d4
alpine v60
12.5 VGA flip down
Nettop pc w/10" touch screen
78nova
5-re audio 5x7 ,10" sub &
Xtx-500.5
