speakers and sub shutting off
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=105967
Printed Date: June 01, 2024 at 10:05 AM
Topic: speakers and sub shutting off
Posted By: eaks
Subject: speakers and sub shutting off
Date Posted: July 07, 2008 at 2:42 PM
hey guys.. im running into some huge issues with my stereo!
What im running..
MTX thunder amp (think its like 300watt rms)
infinity 6.5s in my doors (running off the mtx amp)
stock tweeters and stock 6x9s in the rear (running off deck)
deck is an alpine ida-x001
pioneer class D mono block amp (600watt rms)
kicker L7 12"
Issue: Everything was running fine for awhile after i installed my new pioneer in my trunk to replace my failed kenwood amp! I then installed new racing seats in my car (the mtx amp is located under my driver seat).. Everything worked fine for a few days.. Then i would have my speakers and sub shutoff at random times and then just fire back up.. i checked all wiring in my car and everything and it was all good..
Then yesterday i noticed it shutting down (speakers and sub) for longer periods of time and it wouldn't come back on for some time.. then today i start up my car and all i have is my tweeters and 6x9s.. drove for awhile and a couple times my speakers and sub would kick on for a second (long enough for one good hit) then shut down.. i went directly home.. and looked over everything.. my 25amp fuse was blown (and actually kinda melted) in my mtx amp.. the 2 40amp fuses in my pioneer amp were both good.. checked my fuse under the hood and it was fine.. then i checked at the back of my deck and the remote wires were both connected and still soldered together fine.. I now checked the voltage at my amps and both have 12 volts at the terminals and with the stereo on the remote wire is showing .2 volts (which is correct if i remember correctly).. i replaced my mtx amp with a 30amp fuse i had laying around (just to test) and nothing would work..
Im going to pickup a bunch of 25 amp fuses tonight hopefully and then check everything again tomorrow but i dont see where the issue can be.. and i checked all wires for frays and stuff and they are still all fine (under the drivers seat)..
Does anyone have any ideas?
And theres not really any stereo guys i know about around here as most people come to me for help/installs..
Posted By: KPierson
Date Posted: July 07, 2008 at 2:47 PM
Where were you measuring voltage at? Directly at the amp? I would guess that your amp is grounded to your seat and not making a solid connection. That is where I would start. And your remote wire shouldn't read 0.2vdc - it should read 12vdc whenever the radio is on. ------------- Kevin Pierson
Posted By: eaks
Date Posted: July 07, 2008 at 2:59 PM
Hey man! Ya I was measuring directly at the amp! And since I was getting 12 volts there I'm sure my ground is good! Although will check later! And the remote should read 12 volts with the deck on? That's gotta be my problem then! Ill check my remote from the deck and my power antenna as well!
But the remote wire should show the same reading as the possitive teminal on the amp?
Also: just checked and both my remote and my power antenna wires from my deck give me 0.2 volts when the stereo is on! So what's happening here?
Posted By: joch1314
Date Posted: July 07, 2008 at 5:12 PM
yeah..... 0.2 volts is not what it should be putting out! How close together are the ground and remote wires on your amp! if even a tiny (one)strand of the ground wire touches the remote wire terminal then more than likely it will shut off that circuit, but the radio will continue to play! Disconnect the remote wire from both amps and test the voltage when it's not hooked up to the amps! make sure you reset the radio as well. Also, check ALL of your remote wire....you said you changed the seat and that your mtx amp is under the seat..you might have pinched the wire when you bolted the new seat in. Makes sense to me, as that is the only amp with blown fuses....that would also be the reason that your pioneer amp is not working, (i'm assuming that you just jumped the remote wire to both amps!) ------------- ...half of the truth can be worse than a lie. <----Roger Russell said that..
Posted By: eaks
Date Posted: July 07, 2008 at 10:07 PM
Hey man! Just did that and it fixed it! That is till I drove then the exact same thing happend!
Posted By: joch1314
Date Posted: July 08, 2008 at 12:17 PM
What exactly did you do, and what happened when you tested the voltage on the remote wire after you disconnected it from the amps! Try this.....see if it cuts out when you only hook the remote to your pioneer amp! then try it with your mtx amp! i'm thinking it'll cut out when your mtx amp is hooked up and not when your pioneer amp is hooked up! if that's the case then i'm thinking that something fried on your mtx amp! don't forget to test the voltage before and if and when it cuts out....test it again! ------------- ...half of the truth can be worse than a lie. <----Roger Russell said that..
Posted By: eaks
Date Posted: July 08, 2008 at 2:16 PM
Just got home from work! Need to run and have a shower and then work on the car! I was acutally gonna test that tonight!
Posted By: eaks
Date Posted: July 08, 2008 at 6:37 PM
ok guys.. well heres something weird.. i reset my deck and hooked up only my pioneer amp and then it was thumping pretty good.. then i drove down the road and bam it died again!! So now im like wth.. and then i get to futureshop (where i was gonna check out the warrenty on my mtx amp) and i start playing with everything.. and i cannot get 12V at my remote wire anymore.. have my fuses pulled from the possitive wires, and have teh remote wires removed from the amps and reset the deck numerous times and still nothing.. i get anywhere from 0.1v-0.6v at the remote wire..
any ideas? im gonna go out and try it a few more times right now!
Posted By: joch1314
Date Posted: July 08, 2008 at 6:59 PM
now it sounds like something with the remote output on the deck! something has to be causing your remote wire to turn off. i'm kind of out of ideas....only other thing i can think of now...is to run a completely new remote wire. you may even have to relegate to maybe taggin into an accessory wire or ignition wire and see what that does! MAKE SURE YOU FUSE IT! 1 AMP/3 AMP SHOULD DO! Anybody else have any ideas!! ------------- ...half of the truth can be worse than a lie. <----Roger Russell said that..
Posted By: DYohn
Date Posted: July 08, 2008 at 7:28 PM
Wow! You guys like using exclamation points!! Sounds like your head unit may be defective. Get it checked out. ------------- Support the12volt.com
Posted By: eaks
Date Posted: July 08, 2008 at 7:57 PM
exactly what i figured it down to.. im gonna call alpine tonight (prolly closed tho some hopefully tomorrow).. but tonight what i did as a test was just put a jumper wire between the battery wire and my remote wires on my amps and ran that for like an hour of cruising tonight and everything was great.. so its gotta be an issue with my deck output.. gonna call and see if they will replace it and if not i will most likly just throw a wire from battery to amps with a switch (and fuse of course) but my deck should still be under warrenty!!
And i am just gonna have to keep pulling my main battery fuse everytime i turn my car off (till i get my deck fixed) so i dont kill my battery..
But im kinda happy it isn't one of my amps!!
Posted By: joch1314
Date Posted: July 08, 2008 at 8:10 PM
That's the last possible thing it could've been. I'm really hesitant to start blaming the problem on the actual components as most of the time it's the actual install. In this case i guess the only thing it could be is the remote output from the deck...everything else checked fine so, you're right...good thing it's not the amps. You could hook your remote to an accessory wire in the vehicle, that way it turns off when you turn the car off. seems easier to do it that way. What kind of car do you have? Hey DYohn....no exclamation points.....lol ------------- ...half of the truth can be worse than a lie. <----Roger Russell said that..
Posted By: eaks
Date Posted: July 08, 2008 at 8:27 PM
its an srt4.. i know tonz of places to run wires for accessory or ignition.. i do tonz of lighting mods in my car so know where to hook em up.. id really rather get my deck fixed tho!!
Posted By: DYohn
Date Posted: July 08, 2008 at 9:35 PM
Koo... ------------- Support the12volt.com
