2 12 kicker l5’s in 00 ram quad cab
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=106027
Printed Date: October 31, 2024 at 5:57 PM
Topic: 2 12 kicker l5’s in 00 ram quad cab
Posted By: offroadzj
Subject: 2 12 kicker l5’s in 00 ram quad cab
Date Posted: July 09, 2008 at 9:51 PM
I finally got off my *** and decided to make my 12" L5 fit under my back seat. It required a 2" seat lift and a box that barely fits the sub inside. The extra 2" actually makes the seat more comfortable as it still leaves plenty of head room and gives more leg room. the current lifts are temporary until I can get 2 blocks to space it with. The seat back no longer locked in place so I drilled out the metal to fit 2 plastic panel clips which snap in to 2 holes drilled in the back support. It works like a charm. I ended up building a second box to run a second L5 hopefully soon. I had a kicker 700.5 5channel, and I just picked up a second one for cheap so I will eventually have both amps working, which will put out approx. 400w to each sub. Cant wait to get the second sub in there.
I snapped a couple pics.
posted_image
posted_image
posted_image
Kenny
Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
Posted By: still_walkin
Date Posted: July 23, 2008 at 7:20 PM
Nice the only thing I would do is get some fabric to match the seat and cover the gaps between the subs for a clean look
1993 sdv
Alpine 4x6 6x9 5 1/4 swr-10d4
alpine v60
12.5 VGA flip down
Nettop pc w/10" touch screen
78nova
5-re audio 5x7 ,10" sub &
Xtx-500.5
