new hu 2002 mitsubishi diamante
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=106866
Printed Date: May 02, 2024 at 12:19 PM
Topic: new hu 2002 mitsubishi diamante
Posted By: aaron8699
Subject: new hu 2002 mitsubishi diamante
Date Posted: August 18, 2008 at 9:13 AM
I am trying to hook up a stereo in my brothers 2002 Mitsubishi Diamante. When I pulled the cd player out I noticed that the harness only had I think 5 wires. It also has the round plug with 6 pins I think that must go to the amp in the back. Is there an adapter for that round plug to go into the cd player with rca's or do I need to bypass the amp or use in line converter.
I was also wondering why it has 2 plugs in the back that look like the normal fm plugs. One must be for fm but im not sure of the other. There is also another small harness that just has 1 wire, is that the turn on for the stock amp?
Any info would be great, thanks
Posted By: 97gss
Date Posted: August 18, 2008 at 10:42 AM
Battery WHITE/ YELLOW (+) RADIO HARNESS
Accesory WHITE/ RED (+) RADIO HARNESS
Ground BLACK (-) RADIO HARNESS
Illumination RED / BLACK (+) RADIO HARNESS
Dimmer RED (-) RADIO HARNESS
Power Antenna YELLOW/WHITE (+) RADIO HARNESS
Amp Turn On YELLOW/WHITE (+) RADIO HARNESS
LF Speaker (+) WHITE
LF Speaker (-) ORANGE
RF Speaker (+) YELLOW
RF Speaker (-) BROWN
LR Speaker (+) RED
LR Speaker (-) GREEN
RR Speaker (+) BLUE
RR Speaker (-) BLACK
Amp Location MOUNTED TO BRACKET IN RIGHT SIDE OF TRUNK
Steering Cntrls YES
  THIS VEHICLE MAY BE EQUIPPED WITH OPTIONAL ONSTAR® TELEMATICS EQUIPMENT. USE AN APPROPRIATE INTEGRATION HARNESS OR INSTALLATION PROCEDURE TO ENSURE PROPER FUNCTION OF THIS EQUIPMENT.
Speed Cntrl NO
Radio Security YES
Security
When you say "2 fm wires" do you mean antenna plugs?  If so, it may have diversity antenna in the back window like the older ones did.  Just use the bigger antenna plug.  I haven't worked on a 2002 model but it may be the same as the older ones.
Date Posted: August 18, 2008 at 11:27 AM
Yes the "2 fm wires" I am talking about are the antenna plugs, I will just use the bigger one.
As for the speaker wires I thing they all run off the amp because none of them are in the harness for the hu. I imagine the round plug with the 6 pins in it goes to the amp but I dont have a way to convert that to put it in the new cd player. Thanks for the quick response
Date Posted: August 19, 2008 at 10:43 AM
I found what I was looking for. Amplifier integration harness for mitsubishi that has a special round plug.
