high’s drain when bass gets loud
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=107329
Printed Date: May 15, 2024 at 2:49 AM
Topic: high’s drain when bass gets loud
Posted By: akickz
Subject: high’s drain when bass gets loud
Date Posted: September 09, 2008 at 11:22 AM
Alright, Im running four alpine type-r's, on 1 jl 1000/1, I have all my inside highs (4 pioneer 6 1/2's & 2 pioneer 6x9's) running off of a jl 300/4 amp. I also run a zapco SEQ (aka zap board), and when i bring the bass up on the equilizer the highs are no longer crisp, it seems as if they are drowned out. They Still Play but they sound very static like. Im wondering if the 1000/1 is pulling more power than the 300/4. I run 0 guage, 300A fuse, Yellow Top Optima up Front and In the Trunk, 200A HO Alt. I've never run into this problem, and i've been having this setup for a while. Any Insight?
Posted By: reax222
Date Posted: September 09, 2008 at 2:38 PM
Try it again with the sub amp unpluged. If it still drowns, the subs aren't the cause.
Posted By: akickz
Date Posted: September 09, 2008 at 6:01 PM
Yah I tried that it still drowns
Posted By: audiocableguy
Date Posted: September 09, 2008 at 6:55 PM
The Zapco SEQ has been out of production for a while.
The static you here could very well be a bad slider(s).
Email the guys at zapco and ask if they have experienced
this.
Posted By: jazzcustom131
Date Posted: September 09, 2008 at 7:04 PM
Why yes, it is pulling more current, as it produces more power and probably has more thermal output.
Are you sending the signal from the Zap board to both amplifiers? Perhaps you should send that altered signal to only the Mid/High Range amp, and let the sub amp use it's on board eq's to deal with your subs cut off range? ------------- Greed is for amateurs.
Disorder,chaos,anarchy now THAT is fun!!
Date Posted: September 09, 2008 at 8:39 PM
"I bring the bass up on the equilizer the highs are no longer crisp" mmmm you adjust the EQ and the condition appears. This screams signal problem.
JL amps use Regulated Power Supplies. I highly doubt your problem is voltage. Disconnect the SEQ, run the signal directly to the amps and see what happens.
Posted By: akickz
Date Posted: September 09, 2008 at 11:40 PM
yes to answer your questions I am running the seq to both amplifiers. I know it is out of date I recently had it serviced by a local person who deals with zapco's at his shop and the guy said it was working perfectly. Maybe I need to have it checked again?
First I will try and disconnect the zapco seq n report if my problem still continues.
Another ?. I know my eq is out of date. Is their any current equilizers that would better suit or better help my setup?
Posted By: chillin420
Date Posted: September 10, 2008 at 12:27 PM
check out audio control... some of the best product i have ever used ------------- you can do it....
advanced MECP, lol does it really matter....
patience is a virtue
Posted By: daboss593
Date Posted: September 10, 2008 at 2:26 PM
i had a sim problem happen but not with your type or gear turned out my amp was getting to hot?
------------- OWWWWWWWWWWW you said you discharged the cap!
