subs cutting out
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=108006
Printed Date: June 10, 2024 at 12:37 AM
Topic: subs cutting out
Posted By: elemen0hpey
Subject: subs cutting out
Date Posted: October 08, 2008 at 1:30 PM
I have 2 10" Alpine Type-r dual 2ohm subs, hooked up to an Alpine M1000 at a 2 ohm impedence hooked up to the stock head unit with a hi/lo converter or whatever you call it.. Im running 4 gauge to the block, and 4 gauge to the amp... every time the subs hit hard with loud music only, they cut out.. Whenever I shut off and restart my truck, they work again and then cut out at a heavy hard bass note. I haven't done the big 3 just yet.. what could this be? My lights do dim at night with the music up. maybe the amp is going into low voltage protection mode?
------------- hello
Posted By: haemphyst
Date Posted: October 08, 2008 at 2:39 PM
Yep... Fix your electrical soon, or you're gonna be buying a whole lot more than "Big Three" parts.
------------- It all reminds me of something that Molière once said to Guy de Maupassant at a café in Vienna: "That's nice. You should write it down."
