2000 civic cx hatchback fuse blowing
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=108827
Printed Date: May 21, 2026 at 2:48 PM
Topic: 2000 civic cx hatchback fuse blowing
Posted By: taluxek9
Subject: 2000 civic cx hatchback fuse blowing
Date Posted: November 11, 2008 at 3:40 AM
Just moved my stereo equipment from my 93 grand cherokee into my civic.  System consists of a Pioneer 7900BT deck, Soundstream II power distribution block, Infinity 60.7 cs component speakers in the front powered by an Infinity 475a 4 channel amp.  In the back I have an alpine 10" type r running off of a alpine mrp650.
I have everything wired correctly(at least i've double-triple checked it and whatnot).  So I connect the power lead to the battery, and turn the car to the acc. position, and nothing comes on except the distribution block.  So my reasoning is that the remote wires from the deck are not sending a turn on signal to the amps.  This is confirmed when I find the under hood radio fuse blown.  I had taken the radio power wire apart to see if i had soldered it well enough.  I plugged the fuse back in, and *then* reconnected the wires from the harness to the radio.  The fuse blew again.  What is the problem here(if im not being too vague, sorry if so, ask questions and i can try my best to answer them.)  and how do i fix it?
Posted By: i am an idiot
Date Posted: November 11, 2008 at 6:42 AM
Unplug the radio harness and see if it is still blowing the fuse.
