4 re 10’s enclosure, 93 s10 blazer
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=109325
Printed Date: March 05, 2026 at 7:13 PM
Topic: 4 re 10’s enclosure, 93 s10 blazer
Posted By: jshultz
Subject: 4 re 10’s enclosure, 93 s10 blazer
Date Posted: November 29, 2008 at 3:22 PM
I've been building boxes for years now, but I'm having a problem with the enclosure I built for my blazer, 4-re 10's firing up-ish, kind of angled towards the rear window, but not much, it's loud as I want it to be, but about 30hz or so it falls flat on it's face, I've built about 10 or so boxes for my extended cab s-10, all firing down and they play down to 25 hz or so with no problem, I started at 32 hz on the tuning freq, just re-tuned it today to about 27, with no improvement, it got louder on the higher bass. If I was to build a plate that covers the subs, with about a 3-4 inch gap over them would that help me pick up the lower frequencies? just something for them to resonate off of?
Posted By: aznboi3644
Date Posted: November 29, 2008 at 5:11 PM
no...what is the net volume and tuning of the enclosure???
I have single Memphis 15 PR in a ported box I built tuned to 40Hz...plays 30Hz no problem.
Posted By: soundnsecurity
Date Posted: December 01, 2008 at 9:19 PM
are they all sharing the same chamber or do they have dividers for each sub? they might be interacting with each other a little bit. just a thought
Posted By: jshultz
Date Posted: March 23, 2009 at 12:18 AM
the enclosure is 2 chambers, very close to 4 cubes after driver and brace displacement, Exactly what re calls for. I thought it was a problem with my ipod, (mentioned in another topic) but i've heard other systems running on ipods and they play the lower notes with no problems. I've always put 4 10's in 6 cubes ported before in the past and they all played deeper than these. Go figure, the first time I use the manufacture's specs I'm not happy. lol. Tomorrow I'm going to give it the poly-fill treatment, if that doesn't cure it I'll just build a bigger box. I want to fire them towards the rear, but my blazer has the inside spare tire, I only have about 28 inches width to work with, and I don't want to double stack the subs to where the box comes above the rear seat.
