two batteries hook up
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=109925
Printed Date: June 04, 2024 at 5:15 PM
Topic: two batteries hook up
Posted By: juliojr@614
Subject: two batteries hook up
Date Posted: December 21, 2008 at 8:20 AM
Can some draw up a pic for the hookup of 2 batteries to 2 ampz how is this done
------------- Julio C. Ortiz Jr
Posted By: CutDog504
Date Posted: December 21, 2008 at 8:55 AM
There are many different ways to wire it up. It would be best if you explain what you want to use this setup for "two amps" is pretty vague. Is it two 100 watt amps, or 2 1500 watt amps?? Are you trying to wire in 2 additional batteries (3 total) or 1 extra battery(2 total)? Is this for a daily driver? Or is this a show or competition vehicle? Will you be playing the stereo with the car engine not running? And if so, will it be for extended periods? You need to take all of this into account to determine what will be the best wiring setup/configuration for your particular application.
Date Posted: December 22, 2008 at 12:38 AM
2 batteries total 800 watt amp 4 the door and front and 1200 4 the bac with 2 tv mon.
