required voltage/amperage
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=112010
Printed Date: May 23, 2026 at 9:18 AM
Topic: required voltage/amperage
Posted By: y2j514
Subject: required voltage/amperage
Date Posted: February 28, 2009 at 11:21 PM
Ok so I have a spare car amplifier running around, and I also can get a power converter from AC to 12V DC with 0-29A.  I was wondering if this power converter would be "strong" enough to run an amplifier.  I figured with the extra amp lying aroud I could wire it up to my tv, and use a "homemade" surround sound system with the extra junk lying around.  I'm not sure how many amps an amplifier requires - too me thats it's purpose increase amperage right?
Posted By: haemphyst
Date Posted: March 01, 2009 at 1:53 AM
How many watts is it? Generally, figure this:
Output power * 1.5 = Input power
Input power / 12 = Input current
To go the other way around...
You have 29A. 29A * 12V = 348W
348W * .6 (60% efficiency) = 208W
208W / 2 = 104 WPC RMS
That 29A power supply will power *up to* a 100 WPC amplifier comfortably.
Posted By: y2j514
Date Posted: March 01, 2009 at 9:57 AM
Im assuming 208W/2 = 104 WPC is you assuming its a 2 channel amplifier correct?  If its a 4 channel amp then it would be 52WPC etc....
So assuming a 2 channel amp, and the 104WPC limitation - I wouldnt want to set the amp to put out a constant 100W - because of the fluctuations right?  That would be like the max output, so I would want to set it somewhere around 80W RMS?
Date Posted: March 01, 2009 at 1:09 PM
Already figured into the calculations. Peak power comes from within the amplifer, generally, and I am still going to stick with the 100 WPC safe range. 20 watts per channel will make zero audible difference anyway.
Unless you are running sine wave power, (but who listens to sine waves, anyway?) there will be no WAY for you to "set the amp to put out a constant 100W". Music doesn't behave like that.
Posted By: y2j514
Date Posted: March 01, 2009 at 1:20 PM
Sorry, I used the wrong wording there - I didnt mean a constant 100W.  What I mean is adjusting the gain to make it louder etc.  Wouldnt the amplifier start clipping earlier than it would normally?
Although I guess it doesnt really matter; in the end all I have to do is just adjust the gain like I normally would...
