new alarm now have engine whine
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=112924
Printed Date: May 28, 2024 at 7:55 PM
Topic: new alarm now have engine whine
Posted By: leoeayers
Subject: new alarm now have engine whine
Date Posted: April 05, 2009 at 2:09 PM
I installed a viper 5900 r/s in my 2002 lincoln ls and Now I have a whine in my radio. Didnt have any prob before I installed the alarm. The headunit is a pioneer avh600dvd 2 kicker amps 1 for highs and mids 1 for subs. alarm just has the brain for the alarm normal sensors for the alarm and a 452d dei module to isolate the normally closed door triggers. everything works great for the alarm but the noise in the radio is deafing!
Posted By: i am an idiot
Date Posted: April 05, 2009 at 3:05 PM
Date Posted: April 05, 2009 at 3:35 PM
Is that a possibility even if the noise is there when the car isnt running prob wasnt there before the alarm went in
Date Posted: April 05, 2009 at 4:11 PM
I didn't catch that part, which amp is the noise coming from? With the system turned on but no volume, touch each of the amps individually, does either of them produce a hum in the speakers when you touch them? What are the model numbers of the amps?
Date Posted: April 05, 2009 at 4:36 PM
I did what the link said took all the noise went away. Gonna send the radio back to Pioneer its still under warranty. Thanks for the help
Date Posted: April 05, 2009 at 4:54 PM
One of 2 things caused the problem you are having. First possibility is that a power wire touched the shield of the RCA cable, either behind the radio or at the amp. Second possibility is the ground wire was removed from an amplifier with the RCA and power wire still connected to the amp. Either one could have been prevented if you disconnected the battery cable while installing the alarm.
Date Posted: April 05, 2009 at 5:27 PM
Battery was disconnected not sure what happened
