2008 jetta radio
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=113786
Printed Date: April 04, 2026 at 1:47 AM
Topic: 2008 jetta radio
Posted By: destaudio
Subject: 2008 jetta radio
Date Posted: May 13, 2009 at 12:24 PM
Do you have to use the can-bus adapter on this car or can you use a regular VW harness? Also, what will happen if I don't use the adapter?
Thanks in advance for any information!
Posted By: fiberglasslvr
Date Posted: May 13, 2009 at 2:19 PM
yes you must use the can bus adapter on this car dont even attempt without it. many things can happen if you dont , check engine, air bag, etc. it can be a very bad day without that adapter.
in process of changing everything
Date Posted: May 14, 2009 at 11:39 AM
Yea, that's what I figured, just wanted to make sure. Thanks for the reply.
