ppi and alphasonik amp
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=113863
Printed Date: May 03, 2026 at 9:42 PM
Topic: ppi and alphasonik amp
Posted By: toomtoomvroom
Subject: ppi and alphasonik amp
Date Posted: May 17, 2009 at 7:48 PM
Hey there, first off thanks for reading and for any input you can give. I have an PPI PC6600 and a Alphasonik PMA5753A The specs are
Alphasonik PMA5753A
75 X 4 + 260 x 1 @4ohms
125 x 4 + 400 x 1 @2ohms
PPI PC6600
6 x 50W @ 4 ohms
6 x 100W @ 2 ohms
3 x 200W @ 4 ohms bridged
Will either of these amps be able to run a 8W7 without any problems? And why do these amps only have front and rear inputs? Why not inputs for subs? I know Alphasonik arn't really known for their amps or quite frankly anything else, prob why they went bankrupt, but after hearing one at a store i figured i'd try it out. I also got it for dirt cheap so that helps too. Once again thanks for any help.
One last question, does anyone know where i can get a bass remote for the Alphasonik? It's a 4 pin telephone jack type. I have the remote, but on the remote it's a 6 pin. I don't know if they have a cable from 4pin to 6pin, or if the remote i have is for a different Alphasonik Amp.
Posted By: i am an idiot
Date Posted: May 17, 2009 at 8:27 PM
What impedance is the 8W7?   I know that they will handle tons of power.  If it is available in a dual 4 ohm or a single 2 ohm coil, the 400 watts from the Alphasonik may be enough power for that driver.
Posted By: ianarian
Date Posted: May 17, 2009 at 9:05 PM
You can get the w7 to play without problems, Yes. Its possible.
"Opiniarian"(Ianarian+Opinion): W7'S are a different level of just speakers and amps. I wouldnt do it.
As far as the inputs, are the amps older models? That may be why they were cheap.
I cant recall Alpha having remote LPL's on that 5ch. I remember the voltage meter port that they had. In the phone world though, 4 pin(rj11) plugs into a 6 or 8 pin but only uses the pins that connect on both sides. But if that remote is suppose to be for that amp, they may have a weird pin-out that they configured. I would try to find that certain patch cord to see if it exists. Google will tell ya.
Date Posted: May 17, 2009 at 9:59 PM
I think the W7 only comes in 3ohms.
Hey ianarian, why wouldn't you recommend it? Also thanks but i've tried to google it a million times. It's hard since the company has gone out of business to find much information. I've actually found their UK website with all their products, but it wasn't very helpful.
