6.5 subs
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=114090
Printed Date: May 22, 2024 at 8:07 PM
Topic: 6.5 subs
Posted By: spmpdr
Subject: 6.5 subs
Date Posted: May 29, 2009 at 12:46 AM
first my set up MBquart 6.5 component front stage powered by a kenwood 500 x 4 . 2 12" mb quart discus in rear of single cab dodge ram pu.
now my question: i want to know if putting a set of 6.5 subs in my rear panels would give me nicer sq or more bass? they would be about 130watts rms probably some jl audios thanks
------------- -A vision without a plan is just a hallucination-
Posted By: panerailover
Date Posted: May 29, 2009 at 8:55 AM
I would.. I like quality bass, nice and tight.. check JLs
------------- 01 Lexus GS430 SOLD.. 04 BMW 545i Sport, NAV Logic7
Posted By: spmpdr
Date Posted: May 29, 2009 at 8:18 PM
what is the difference between a 6.5 " subwoofer and a mid bass driver?
the frequency response was just about the same30-300hz . I also would like to know what you think about ma audio stuff.
Posted By: i am an idiot
Date Posted: May 29, 2009 at 9:45 PM
MA Audio started life as Mobile Authority. Here is a sample of their earlier work. And yes that is a pack of Marlboro Cigarettes in the amp so you can see how much area is unoccupied.
You really need to check out the JL subs
Posted By: spmpdr
Date Posted: May 30, 2009 at 1:04 AM
can 2 2ohm svc subs be hooked up to a bridged 130x2 4ohm amp wihtout damaging the amp or the subs?the amp is stable at 2ohms i beleive.
Date Posted: May 30, 2009 at 4:45 AM
Yes, you can connect one speaker to each channel of the amp. The amp will produce it's maximum safe amount of power into the 2 Ohm stereo load.
Posted By: DYohn
Date Posted: May 30, 2009 at 9:01 AM
My favorite small subwoofer is the 6.5" from Tang Band. spmpdr asked what's the difference between a subwoofer and a standard woofer, and the answer generally is Xmax. A subwoofer is generally designed with a lot more linear excursion capability than a standard woofer. MA Audio is a cheap brand to be avoided. ------------- Support the12volt.com
Posted By: spmpdr
Date Posted: May 30, 2009 at 9:30 AM
thanks everyone , dyohn on those tang bands, are the 5.25s good too? the reason I ask is that is the stock speaker hole in the cab of my truck so I wouldnt have to modify it to fit the 6.5. they also match my usb specs perfect thanks for the link.
Posted By: DYohn
Date Posted: May 30, 2009 at 9:55 AM
The 5 inchers are OK too. Nice way to augment the low end. Just don't expect big woofer boom. ------------- Support the12volt.com
Posted By: spmpdr
Date Posted: May 30, 2009 at 1:11 PM
do you know what the mounting depth on those6.5 s are the specs are in a formula i dont know. also do you know the mounting depth of the rear panels for a 2003 dodge reg cab 1500? or anywhere i might be able to find that info, thanks again great link
Posted By: ckeeler
Date Posted: May 30, 2009 at 1:16 PM
the 6.5" from Tang Band is an awesome woofer! and yes dont expect big woofer boom unless you use ALOT of them. i used the JL in this enclosure i made and man......it sounded amazing and no joke dude.....this this was loud!
Posted By: icearrow6
Date Posted: May 30, 2009 at 2:04 PM
kick ass. man.
Posted By: spmpdr
Date Posted: May 30, 2009 at 6:48 PM
that is sweet man, does anyone know where to get specs for enclosure for these. the best thing ive come up with is 6" pvc tube about 14" long that would give me .23ft3
