2000 GMC Jimmy Bose Amp Location
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=114675
Printed Date: May 13, 2024 at 6:58 PM
Topic: 2000 GMC Jimmy Bose Amp Location
Posted By: moviejunkie
Subject: 2000 GMC Jimmy Bose Amp Location
Date Posted: June 25, 2009 at 12:31 AM
I am looking for the Bose Amp in a 2000 4dr GMC Jimmy. I have looked all over for it.
Thanks for your Help
Jason
Posted By: soundnsecurity
Date Posted: June 25, 2009 at 9:31 AM
not 100% sure but GM likes to hide their amps under the center console so i would check there.
Posted By: tommy...
Date Posted: June 25, 2009 at 5:18 PM
- JIMMY 2000-02 W. BOSE SYSTEM
UNDERNEATH CENTER CONSOLE https://documents.victorytechnologies.com//documents/product/9539.pdf A1-A4 Not Used A5 Orange... Left Rear Speaker (-) A6 Gray... Left Rear Speaker (+) A7 Dark Blue/White... Right Front Tweeter (-) A8 Dark Blue... Right Front Tweeter (+) A9 BROWN / White... Right Rear Speaker (+) A10 Brown ...Right Rear Speaker (-) A11 Blue... Left Front Tweeter (-) A12 Yellow... Left Front Tweeter (+) B1-B12 Not Used...
------------- M.E.C.P & First-Class
Posted By: tommy...
Date Posted: June 25, 2009 at 5:34 PM
AMPLIFIER LOCATIONS BUICK - RAINIER 2004 W/ RPO CODE UQA
................................................ BEHIND RIGHT REAR PANEL CADILLAC - CTS 2003-04 W/ RPO CODE U57
.....................BEHIND DRIVERS SIDE REAR PANEL IN TRUNK - DEVILLE 2000-04 W/ RPO CODE U57
.BEHIND REAR SEAT - ESCALADE 2000 W/ LUXURY SYSTEM
UNDER CENTER CONSOLE - ESCALADE 2002 W/ RPO CODE Y91
BEHIND DRIVERS SIDE REAR PANEL - ESCALADE EXT 2002 W/ RPO CODE Y91
UNDER CENTER CONSOLE - SEVILLE 1998-04 W/ RPO CODE UX9
BEHIND REAR SEAT - SRX 2004 W/ RPO CODE U57
BEHIND PASSENGER SIDE REAR PANEL - XLR 2004 W/ BOSE SYSTEM .
ON PASSENGER SIDE FLOOR UNDER CARPET CHEVROLET - AVALANCHE 2002 W/ RPO CODE Y91
UNDER CENTER CONSOLE - AVALANCHE 2003-04 W/ RPO CODE UQ7 W/O Y91................................
UNDER CENTER CONSOLE - BLAZER 2000-02 W/ BOSE SYSTEM
UNDER CENTER CONSOLE - S-10 2000-02 W/ BOSE SYSTEM
UNDER CENTER CONSOLE - SIVERADO 2003-04 W/ RPO CODE UQ7 W/O Y91
UNDER CENTER CONSOLE - SUBURBAN 2001-02 W/ RPO CODE Y91
BEHIND DRIVERS SIDE REAR PANEL - SUBURBAN 2003-04 W/ RPO CODE UQ7 W/O Y91
UNDER CENTER CONSOLE - TAHOE Z71/LIMITED 2000 W/ LUXURY SYSTEM
UNDER CENTER CONSOLE - TAHOE 2001-02 W/ RPO CODE Y91
BEHIND DRIVERS SIDE REAR PANEL - TAHOE 2003-04 W/ RPO CODE UQ7 W/O Y91
UNDER CENTER CONSOLE - TRAILBLAZER 2002-04 W/ RPO CODE UQA..........................BEHIND PASSENGER SIDE REAR PANEL - TRAILBLAZER EXT 2003-04 W/ RPO CODE UQA....................
BEHIND DRIVERS SIDE REAR PANEL NOTE Many factory amplifiers are now incorporating the crossovers for the tweeters and subwoofers within the amplifier. When bypassing the factory amplifier, you need to cross over those speakers with either passive crossovers or use an after-market AMP with built in crossovers. INST702054 AMPLIFIER LOCATIONS GMC - ENVOY 2000-01 W/ BOSE SYSTEM
BEHIND CENTER CONSOLE - ENVOY 2002-04 W/ RPO CODE UQA................................
BEHIND PASSENGER SIDE REAR PANEL - ENVOY XL 2002-04 W/ RPO CODE UQA
BEHIND DRIVERS SIDE REAR PANEL - ENVOY XUV 2004 W/ RPO CODE UQA
.BEHIND DIVERS SIDE REAR PANEL - JIMMY 2000-02 W. BOSE SYSTEM
UNDERNEATH CENTER CONSOLE - SIERRA 2003-04 W/ RPO CODE UQ7 W/O Y91
............................UNDERNEATH CENTER CONSOLE - SONOMA 2000-02 W/ BOSE SYSTEM
UNDERNEATH CENTER CONSOLE - YUKON DENALI 2000 W/ LUXURY SYSTEM
.UNDERNEATH CENTER CONSOLE - YUKON/XL/DENALI 2001-02 W/ RPO CODE Y91.........................BEHIND DRIVERS SIDE REAR PANEL - YUKON/XL 2003-04 W/ RPO CODE UQ7 W/O Y91........................
UNDERNEATH CENTER CONSOLE HUMMER - H2 2004 W/ RPO CODE UQ7 W/O Y91
UNDERNEATH CENTER CONSOLE ISUZU - ASCENDER 2003 W/ RPO CODE UQA...............................
BEHIND PASSENGER SIDE REAR PANEL OLDSMOBILE - AURORA 2001 W/ RPO CODE U80
BEHIND REAR SEAT - AURORA 2002-03 W/ RPO CODE U80
BEHIND REAR SEAT - BRAVADA 1998-01 W/ BOSE SYSTEM
.........................................UNDERNEATH CENTER CONSOLE - BRAVADA 2002-04 W/ RPO CODE UQA................................BEHIND PASSENGER SIDE REAR PANEL - INTRIGUE 2000-01 W/ RPO CODE U85
UNDER REAR DECK - INTRIGUE 2002 W/ RPO CODE U85
UNDER REAR DECK PONTIAC - BONNEVILLE 2000-01 W/ RPO CODE U80
BEHIND REAR SEAT - GRAND PRIX 1998-01 W/ RPO CODE U85
UNDER REAR DECK - GRAND PRIX 2002-03 W/ RPO CODE U85
UNDER REAR DECK NOTE Many factory amplifiers are now incorporating the crossovers for the tweeters and subwoofers within the amplifier. When bypassing the factory amplifier, you need to cross over those speakers with either passive crossovers or use an after-market AMP with built in crossovers
Posted By: spookiestylez
Date Posted: June 25, 2009 at 5:43 PM
Where did you pick that up from Tommy? If you feel generous PM me with some details.
------------- RTFM
Posted By: lspker
Date Posted: June 25, 2009 at 9:31 PM
just follow the smell
Posted By: tommy...
Date Posted: June 25, 2009 at 10:24 PM
Description Factory amplifier bypass harness Product Specifications- Factory amplifier bypass harness
- 204" Long
- Must have RPO code Y91
- One 24-pin plug and one 8-pin plug
Allows installation of an aftermarket radio using the existing factory wiring and connectors. No cutting of factory wiring is needed. Will go here when i need amp pinouts...dash removal instructions...Just click on the part that says product instructions...It is metra's website...But the install manuals are there also ------------- M.E.C.P & First-Class
Posted By: tommy...
Date Posted: June 25, 2009 at 10:27 PM
Just either type in the harness or search for the vehicle... there is a product desription for kits, bluetooth, harness, etc...
Posted By: tommy...
Date Posted: June 25, 2009 at 10:28 PM
Generous...Whatever i can do to help...This site has helped me more then a few times...!!
Date Posted: June 27, 2009 at 12:27 AM
thanks guys, I have looked ALL over for that information, it needs to be put on the site
Posted By: i am an idiot
Date Posted: June 27, 2009 at 1:35 AM
Grond Control: To Major Tom. Have a better day tomorrow.
Posted By: tommy...
Date Posted: June 28, 2009 at 9:11 PM
This is Major Tom to Ground Control: Much better day...! ------------- M.E.C.P & First-Class
