15 l7 and a zeus vii amp
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=114797
Printed Date: May 21, 2024 at 6:16 PM
Topic: 15 l7 and a zeus vii amp
Posted By: usi696969
Subject: 15 l7 and a zeus vii amp
Date Posted: July 01, 2009 at 7:51 PM
i have a 15" L7 with dual voice coil and a zeus vii amp 2 channel. i need to know if i can hook 1 channel to 1 voice coil and the other channel to the other coil. will i screw it up? or if anyone knows how to brige zeus vii
Posted By: i am an idiot
Date Posted: July 01, 2009 at 7:55 PM
What is the impedance of the voice coils of your woofer? According to the picture on Ampguts, the bridge terminals are the Left Positive and Right Negative terminals. https://ampguts.realmofexcursion.com/Hifonics_Zeus_VII/outside2.jpg
Posted By: loneranger
Date Posted: July 01, 2009 at 7:57 PM
Shouldn't this be moved to the Car Audio Forum?
------------- Ideal - cmon dude, add to topics in a useful manner, not stuff that is obvious.
Story - Phzzzt! Hey, what happened?! ... Isn't it obvious?
Moral - Never dismiss the obvious.
Date Posted: July 01, 2009 at 8:00 PM
Unless your speaker is a dual 1 Ohm driver, Which I doubt it is, you will be fine connecting one coil to one channel and the other coil to the other channel. They have different forums here, I thought they only had this one. https://www.the12volt.com/installbay/last100.asp
Posted By: KarTuneMan
Date Posted: July 01, 2009 at 10:24 PM
Correct me if I am wrong! That amp is from "the good old days" when HiFonics was testical breaker material.
Posted By: howie ll
Date Posted: July 02, 2009 at 2:53 AM
And Gary and Craig when you find a really good 10" sub that works in a free air i.e. no sub box format please let Uncle Howie know. I've just been unearthing some nice Soundsteam and Nak old school stuff.
Date Posted: July 02, 2009 at 5:30 AM
Yes KTM that was the last series of the line that was worth more than the aluminum of the heat sink. And Howie if I stumble across such a beast, I will let you know.
Date Posted: July 02, 2009 at 2:31 PM
4ohm coil and its a zues Vl
Posted By: glass22
Date Posted: July 02, 2009 at 4:34 PM
yes you can
Date Posted: July 02, 2009 at 6:59 PM
It is just like the series VII. Uses the same bridge wires and is capable of 2 Ohm stereo or 4 Ohm mono. If you insist on bridging that amp on that speaker, you must wire the voice coils in series and bridge the amp into the 8 Ohm load. Option 2 (series) = 8 ohm load Voice coils wired in series Recommended Amplifier: Stable at 4, 2, or 1 ohm mono | |
Date Posted: July 02, 2009 at 8:41 PM
glass22 wrote:
yes you can
will it mess it up yes or no
Date Posted: July 02, 2009 at 9:18 PM
Yes you can connect it like that. No it is not going to mess it up.
Posted By: glass22
Date Posted: July 02, 2009 at 10:49 PM
usi696969 wrote:
glass22 wrote:
yes you can
If it would "mess it up" i would have said no orginally. You will be fine hooking up 1 VC to 1 Channel. What are the watts on the amp?
