headunit not getting power
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=115516
Printed Date: June 10, 2024 at 3:08 PM
Topic: headunit not getting power
Posted By: yepitszo
Subject: headunit not getting power
Date Posted: August 07, 2009 at 11:55 AM
Whats up guys .. Okay I've had an aftermarket stereo for a long time but then it broke and so I've had the stock HU in for the past three months.
Well today I decided to get another aftermarket unit again... I started hooking up the new unit to the wiring harnesses I had and it came on temporarily because I had not yet fully secured the wires. But then all of a sudden I couldn't get ANY power.
So I hooked the Stock HU back up but now only the clock comes on for a minute or two ... it can eject and accept cds but it still doesn't appear to have power. It's all hooked up stock again and the AUDIO fuse on the side of the door is brand new.
I've tried everything I could think of plus searched the forums...
Any idea on whats going on? Or What I'm missing? Thanks in Advance!
Posted By: KarTuneMan
Date Posted: August 07, 2009 at 12:20 PM
Posted By: yepitszo
Date Posted: August 07, 2009 at 12:22 PM
sorry I copied and pasted from a car specific forum ..
2005 Ford Explorer Sport Trac
Posted By: i am an idiot
Date Posted: August 07, 2009 at 8:10 PM
The fuse you need to locate is probably going to be labeled Radio. The radio requires 2 power sources to come on. The fuse labeled Audio is for the constant voltage to the radio and for the OEM amplifier. Look for a fuse labeled Radio. You are missing the switched/accessory voltage.
------------- Let's Go Brandon Brown. Congratulations on your first Xfinity Series Win. LGBFJB
