rca cables have ground wire
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=116295
Printed Date: May 29, 2024 at 4:34 AM
Topic: rca cables have ground wire
Posted By: spmpdr
Subject: rca cables have ground wire
Date Posted: September 13, 2009 at 10:38 AM
i got some new rca cables that are made by ma audio mac 12 they have a ground wire in them that runs end to end do i need to use this?If so do I just ground to chassis somewhere?please explain?
------------- -A vision without a plan is just a hallucination-
Posted By: tommy...
Date Posted: September 13, 2009 at 12:34 PM
This wire is usually for The Remote Turn-On...Its kinda like an all-in-one...!
------------- M.E.C.P & First-Class
Posted By: spmpdr
Date Posted: September 13, 2009 at 3:07 PM
If i am already running a remote wire do i need to tape the ends of them off or anything so they dont ground out on any metal?
Posted By: tommy...
Date Posted: September 13, 2009 at 3:10 PM
Well that wont effect the rca's..I guess there is a chance that one end would be touching ground and the other end come over and touch inside rca...So sure tape it up...!
Posted By: i am an idiot
Date Posted: September 13, 2009 at 5:11 PM
That wire has a couple uses. I think it was put in there to allow you to ground one end with the radio's ground wire, and the other end was to be grounded with the amp's ground wire. You know how they say it will reduce the chance of noise if your amp and radio are grounded to the same location. In my opinion, the wire is a bit small to be used for this. It is large enough to use as a remote wire.
