strategic sound deadening
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=117886
Printed Date: May 21, 2026 at 9:58 PM
Topic: strategic sound deadening
Posted By: comfy_shoes
Subject: strategic sound deadening
Date Posted: November 20, 2009 at 5:49 PM
hello. I would like to sound deaden my trunk as my trunk lid and tail light and bumper section resonate terribly. however I feel that covering every square inch of the trunk may be benificial is this overkill? a car audio salesman recommended that I place small sections throughout the trunk instead of covering the entire trunk. and can anyone recommend an affordable product /dealer in southwestern ontario(canada) if not I am aware of products from bquiet.com to be of excellent quality and value. I may go that route. I also drive a 1997 accord exr ....(ex in america)....
as well I should mention I have an infinity 12" reference 1260w sub.... I am crossing it over at 160 althow I am aware that most recommend 100 or lower....however I have found the response and sq to be great at that crossover frequency. and recommendations in fireing direction or trunk position for a high crossover 12" sub????? if it was at 100 or lower I would assume it wouldn't matter. since it is at 160 will there be more of a critical issue mith noticable midbass? it is in a sealed encloser and the infinity specs say it's ok up to 400 crossover point.thanks
Posted By: boogeyman
Date Posted: November 20, 2009 at 6:58 PM
 Talk to Ant at second skin......1-800-679-8511........if im not mistaking he says 25 percent coverage is adequote....
Date Posted: November 21, 2009 at 7:56 PM
hi there. are there any good web sites that offer information,tips and advice on sound deadening? any advice would be very appreciated. thanks
Posted By: KarTuneMan
Date Posted: November 25, 2009 at 9:57 AM
There is no such thing as too much.
https://hushmat.com/
Posted By: necessaryevil
Date Posted: November 25, 2009 at 3:22 PM
cover every inch except the back deck(the divider between the trunk and the passenger compartment) here check theses guys out https://www.dynamat.com/
time is not wasted when you are wasted all the time
