subwoofer box question
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=11866
Printed Date: May 14, 2024 at 5:00 AM
Topic: subwoofer box question
Posted By: Homicyde
Subject: subwoofer box question
Date Posted: April 06, 2003 at 5:41 PM
if im building a box for 4 fifteens is it a good idea to have an open box (ie no dividers) or use dividers??? What about for 8??
------------- Homicyde-
Posted By: esmith69
Date Posted: April 06, 2003 at 5:53 PM
Each sub should have it's own airtight section within the box, and each section should have an internal volume that matches that of the manufacturer's recommended numbers for the subs.
Posted By: djfearny2
Date Posted: April 06, 2003 at 7:05 PM
if it is sealed than use dividers. if it is ported than you will most likeley need the room/.
------------- Jon
Installer/Help Technician
---coral springs florida---
Posted By: midwayelec
Date Posted: April 07, 2003 at 7:27 AM
Actually if you're running all 4 subs off the same amp (which I really hope you're not doing) it would be fine for the subs to share an enclosure without dividers. However, due to the inconsistencies of amplifiers, when using more than 1, you'd definitely want to divide the enclosures.
------------- Sean Cawby
Midway Electronics
Rensselaer, IN
219-866-3716
Posted By: eeh1025
Date Posted: April 08, 2003 at 8:59 AM
What i would do is make one enclosure for each pair of subs so you would have 2 big chambers and 2 subs in each chamber. and i would get 2 of the same amps hook up one to 1 pair and the other to the other pair, you might want to get a cap so that each will get equal amount of volts. did the same thing i made one big box and divided it into 2 chambers, i have 4 Jl audio 12w6s and 2 JBL 1200X1 for each pair, and you can hear me coming from a mile down the raod. no bullsh*t, Just see what every one else thinks.
Ernie
