amp repair
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=119978
Printed Date: April 18, 2026 at 10:55 PM
Topic: amp repair
Posted By: uel_coupe_s
Subject: amp repair
Date Posted: February 08, 2010 at 1:44 PM
I've just got a phoenix gold XS2300 off ebay and it doesn't work. I wired it up to some 6x9's i had lying around to test it, the power light comes on ok but the sound coming out of the speakers (one more than the other) was fierce crackling. The speaker cone was going crazy and after about 10 secs i see the dreaded smoke from the voice coil. I've never done any real electrical repairs before so i need all the help i can get. I've been reading up on various websites and it seems these symptoms are most likely due to blown output transistors. What else is likely to have gone with the output transistors? can i check the power transistors while they are on the pcb or do they need removing? How can i test the input side of the amp is ok? Pcb:
Also there is a burnt resistor (circled) but i cant read the stripes on it to replace it.
Posted By: tommy...
Date Posted: February 09, 2010 at 10:46 PM
https://bcae1.com/repairbasicsforbcae1/repairbasics.htm https://bcae1.com/repairtutorialcdinfo.htm https://bcae1.com/tranfet.htm Some links...Doesnt it look like this amp has been repaired at least once already...? ------------- M.E.C.P & First-Class
Date Posted: February 10, 2010 at 7:34 AM
Your not the first person to direct me to that site, and what a fantastic site it is! I cant see any evidence of previous repairs. The latest development is a clicking sound a few seconds after its powered up, sort of like a relay opening and closing realy fast Thanks.
Posted By: tommy...
Date Posted: February 10, 2010 at 8:10 AM
The "goop" under the transistors is pretty sloppy...That is what lead me to think they have been replaced...? ------------- M.E.C.P & First-Class
Date Posted: February 10, 2010 at 1:38 PM
Yeah i guess it looks worse in the pictures that it is. To me it looks all origonal, with no eveidence of repair work, but i'm not an expert. the solder joins on all the transistors look spot on to me: [IMG]https://i10.photobucket.com/albums/a120/uel_f/CIMG3875.jpg[/IMG]
Posted By: i am an idiot
Date Posted: February 10, 2010 at 6:47 PM
That is not an excessive amount of heat sink compound for a Pheonix Gold amp of that era. I do not see any signs of previous repair. I will look at your pics in a bit.
Posted By: tommy...
Date Posted: February 10, 2010 at 8:09 PM
You would know better then me...Only have opened a few amps...never saw that though...!
Date Posted: February 11, 2010 at 3:49 AM
Do not connect the amp to any more speakers until we get it repaired. I could not find your circle for a while. Notice the 2 silver zener diodes directly above the circle. Chances are one of them is shorted. Do you have a meter? DO NOT REMOVE any parts until they have to come out of the board.
Date Posted: February 11, 2010 at 11:00 AM
Yes i have a meter. I'm not sure what to expect from the zener diodes though, do they need to be removed to test them properly?
Date Posted: February 11, 2010 at 4:17 PM
Do not remove them. Put the meter on the diode test function, touch and hold one meter lead to one leg of the diode, and then the other lead to the other leg. Check both of them and post the numbers you get.
Date Posted: February 11, 2010 at 6:34 PM
I get 0.713 one way, reverse the leads and i get 1.465. Both are about the same. I know normally that would mean the diode has failed, but i dont know with zeners The reading starts lower, and climbs up to the said values where it settles.
Date Posted: February 11, 2010 at 8:11 PM
They are not shorted. Did you use a real camera or was it a phone? If it was a camera, set it to the Macro Focus mode and take a closer picture of the resistors that burnt. The Macro Focus mode will have a green flower symbol. This allows your camera to focus much better when taking close up pictures. Also follow the traces from the burnt resistor to the next components each direction. What component is next in line?
Date Posted: February 12, 2010 at 3:56 AM
yes it was a digital camera used, its just that when the pictures are hosted and put up on this board they are resized and loose all there quality. Can i send them to you via e-mail? I'll check the adjacent components and report back. Thank you.
Date Posted: February 13, 2010 at 10:13 AM
I got your pictures. I will review tonight and see what I can come up with.
Date Posted: February 16, 2010 at 7:59 AM
The only burnt resistor I see is the one near the zener diodes. Have you checked the output transistors to see if any are shorted. You DO NOT HAVE TO REMOVE THEM to check them. If you turned the blue and white adjustments in the amp, turn them both fully counterclockwise. If you have not adjusted them, DO NOT ADJUST them. What is the number off of the actual transistor that has the burnt resistors are near?
Date Posted: February 16, 2010 at 1:46 PM
That burnt resistor isn't actually blown though, its supposed to be a 100 ohm resistor and its reading 97.3 ohms. none of the output transistors read shorted across any 2 of their 3 legs and I havent turned the trim pots. i am an idiot wrote:
what is the number off of the actual transistor that has the burnt resistors are near?
You mean the output transistors? they are IRF540's Should all 3 of the op-amps (at the rca plug end) read the same resistance across thier respective legs? its just the 1 near the gain and bass boost pots is giving different readings compaired to the other 2, which give the same readings. They are all the same part number! Do you know what the one near the gain pot does? or how to test it? Thanks for your help, its much appreciated.
Date Posted: February 16, 2010 at 3:42 PM
The op amps will give you different readings. You are actually reading the circuitry that controls them. 97.3 is well within tolerance. The only problem you have is the shorted output. You really need to replace both outputs on that channel. Are they both 540s or is one a 9540? The reason you need to replace both is that they went through the same abuse, only one of them failed. It could have weakened the other one.
Date Posted: February 16, 2010 at 4:27 PM
None of the output transistors read shorted. When i connect my 12v source to the amp, after a few seconds, when this clicking sound starts, it drops down to 10v, like its sucking far too much current. Any thoughts on this? Cheers.
Date Posted: February 16, 2010 at 4:43 PM
Check the outputs again. It may not read near a dead short. Black meter lead on the tab of the transistor, red lead on the right leg it should read no lower than .400 with the meter set to the diode test function. Black lead to tab and red lead to the left leg should read considerably higher than the previous readings.
Date Posted: February 18, 2010 at 7:19 AM
0.843 0.810 0.843 0.811
Date Posted: February 19, 2010 at 7:52 AM
Turn both of the blue/white variable resistors fully Counter Clock Wise. Place a single 10 amp fuse in the amp. If it is unmounted from the heat sink, clamp all transistors back down and turn it on again. Let me know what happens.
