info center problems, 04 grand prix
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=120803
Printed Date: June 08, 2024 at 8:03 PM
Topic: info center problems, 04 grand prix
Posted By: a.herrera
Subject: info center problems, 04 grand prix
Date Posted: March 19, 2010 at 1:29 AM
got a 04 grand prix gt w/out monsoon system. put a deck useing oso1 harness and chime bypass and now the info center, gas, temp, and rpm gages seem to lose power while drivin then come back on as if no problems at all. anybody got a idea if that was me or if the car is doin it on its own? also the info center loses memory when it happens
Posted By: i am an idiot
Date Posted: March 19, 2010 at 6:20 AM
Connect the radio's yellow wire to the car's constant wire before the harness.
Date Posted: March 20, 2010 at 12:01 AM
but wont that just keep the radio on? also will that fix the static that the bypass is makin? thanks for your advice ill go ahead and do that.
Date Posted: March 20, 2010 at 12:12 AM
The red wire is the one that tells the radio when it can and can not turn on. I am not sure about your particular harness, but several of the harnesses for the newer GM vehicles can not handle the current draw of the aftermarket radio. When they have a problem, they have the same symptoms that you are describing. The amplifier section of your new radio gets its power from the constant feed. If the voltage is dropping, it could definitely cause unwanted noise problems.
Posted By: jeremytravis
Date Posted: March 20, 2010 at 12:25 AM
No, if you connected bolth the red and yellow wires to constant then it would stay on, the yellow wire is suppose to be connected to constant power so your stereo retains all the settings, your just getting the constant power before the harness.
------------- **ADVANCED MECP CERTIFIED
Date Posted: March 20, 2010 at 10:55 AM
There should be no switched power in the factory radio harness, the factory stereo functions with (Class 2 Serial Data)
Date Posted: March 21, 2010 at 2:57 PM
hey thanks guys. thats why it says rookie under my name. ill get rite to it.
